72-80 Leaf spring swap, m880 springs #1440116
05/21/13 10:45 PM
05/21/13 10:45 PM
Portland , Oregon, United Stat...
smokes Offline OP
smokes  Offline OP
I am wondering if '77 Dodge m880 leaf springs are physically the same dimensions as my '78 half ton springs. My 1/2 ton leaf springs do not cut it for any sort of weight in the bed so I figured I would swap on some more heavy duty springs. I went to the wrecking yard and found a '77 m880 with a full suspension on it. I am taking the leaf springs, blocks and u bolts and leaf spring eyelet bolts. I just was double checking to make sure they are physically the same dimensions and will work on my truck? I know that the u bolts/ blocks may be different heights which is why i got them. Eventually I will get the 3/4 ton dana axles but for now I will be just replacing the springs. Any thoughts?
Looking for a clean w150 or w200 **72-80 body style In the Pacific Northwest**
Re: 72-80 Leaf spring swap, m880 springs [Re: smokes] #1440117
05/21/13 10:51 PM
05/21/13 10:51 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
Yes they will fit. I put a set under mt 67 RC. Bolted right in. Lifted the rear about 2 to 3 inches..
I am truckless..
Re: 72-80 Leaf spring swap, m880 springs [Re: smokes] #1440118
05/21/13 10:51 PM
05/21/13 10:51 PM
South-east Mn
blaze Offline
blaze  Offline
South-east Mn
Should be the same. I don't know why they wouldn't be a direct bolt-on replacement.
Re: 72-80 Leaf spring swap, m880 springs [Re: 340SHORTY] #1440119
05/21/13 10:58 PM
05/21/13 10:58 PM
smokes Offline OP
smokes  Offline OP
The rears look 2 or 3 leaves bigger than my 1/2 ones but the fronts look the same width? Do they lift the front as well?
Re: 72-80 Leaf spring swap, m880 springs [Re: smokes] #1440120
05/21/13 11:10 PM
05/21/13 11:10 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
The rears were all I had access to for the rears. The fronts will work also.. I add a Rear hi arc rear main leaf with the ends cut off to my front rc springs. The ride was firmer but not drasticly rough..
I am truckless..
Re: 72-80 Leaf spring swap, m880 springs [Re: smokes] #1440121
05/21/13 11:17 PM
05/21/13 11:17 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The m880 are the same as other 3/4 ton w-200 springs. There is a 7 digit number on each spring which will identify its rating. Everyone thinks the m880 was some special built hd truck which it is not.
Re: 72-80 Leaf spring swap, m880 springs [Re: NITROUSN] #1440122
05/22/13 12:45 AM
05/22/13 12:45 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Re: 72-80 Leaf spring swap, m880 springs [Re: BulletBob] #1440123
05/22/13 04:47 PM
05/22/13 04:47 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Wife cousin had one and sold to a friend that sold to a tard that tried getting $3000 for it and said it had some heavy duty trans (not a 727) and had was heavier duty. The military just rated things different
Re: 72-80 Leaf spring swap, m880 springs [Re: 76dodgeboy] #1440124
05/22/13 06:33 PM
05/22/13 06:33 PM
smokes Offline OP
smokes  Offline OP
Yeah, I noticed that when I was looking at the truck in the yard. Nothing that I saw underneath it or on the truck itself was any different than other 3/4 ton trucks from the same period.
Re: 72-80 Leaf spring swap, m880 springs [Re: smokes] #1440125
05/22/13 06:51 PM
05/22/13 06:51 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
They were all 318 autos aswell
Re: 72-80 Leaf spring swap, m880 springs [Re: smokes] #1440126
05/23/13 03:59 AM
05/23/13 03:59 AM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
The front 3 leaf, leaf spring on the 1/2 and standard 3/4 (including the M88X) are the same spring. And will fit 72-93 trucks.
Same with the rear springs, 72-93 are direct fit.
The only oddball is the 93 diesel front spring. They changed the diameter of the bolt from 1/2 to 5/8. But these too can be a bolt in on a lighter duty truck with a sleeve for the smaller bolt.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: 72-80 Leaf spring swap, m880 springs [Re: hp383] #1440127
05/29/13 04:44 PM
05/29/13 04:44 PM
smokes Offline OP
smokes  Offline OP
Any one know if the u bolts and the plates are the same? I grabbed them all but just want to know if I need to clean the 3/4 ton ones up or if I can use my 1/2 ton ones that are clean.
Re: 72-80 Leaf spring swap, m880 springs [Re: smokes] #1440128
05/29/13 05:11 PM
05/29/13 05:11 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Fits ate same. Some say rears are diff depending on axle tube. I used 9.25 with a D60 and some roughcountry ubolts to load a truck on a trailer. They worked just fine other than having to open the holes for the aftermarket ubolts. Id say either rear should work but if you have the 3/4ton ones handy to clean Id clean and paint and have all ready for the swap
Re: 72-80 Leaf spring swap, m880 springs [Re: 76dodgeboy] #1440129
05/29/13 11:49 PM
05/29/13 11:49 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
the m880 is probably just a heavier rated rear leaf...as in there were probably a few different weight ratings available back then.
the front springs need to be stiffer IMO.
my truck rides and drives much better after putting stiffer springs in the front.
Re: 72-80 Leaf spring swap, m880 springs [Re: 76dodgeboy] #1440130
05/31/13 11:25 AM
05/31/13 11:25 AM
smokes Offline OP
smokes  Offline OP
That was my intention to clean them up a bit and to do the swap. I will soak them in Evapo-rust which is amazing. Harbor Freight sells the stuff and works awesome and much quicker than naval jelly or other rust removal chemicals. On another note if the front leaf springs are the same won't the rear of the truck sit about 2 inches higher? I was thinking about maybe installing an add-a-leaf to the front to make it more level?
Re: 72-80 Leaf spring swap, m880 springs [Re: smokes] #1440131
05/31/13 12:04 PM
05/31/13 12:04 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
It might bring the rear up but not sure. You can always save some coin and pull a leaf from one of the front packs and put in the one you plan to use
Re: 72-80 Leaf spring swap, m880 springs [Re: 76dodgeboy] #1440132
05/31/13 01:24 PM
05/31/13 01:24 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
if you use the m880 block with the springs then it's probably going to sit higher in the rear.
not a big deal though because trucks should sit like that anyway right?
Re: 72-80 Leaf spring swap, m880 springs [Re: krautrock] #1440133
05/31/13 01:32 PM
05/31/13 01:32 PM
smokes Offline OP
smokes  Offline OP
Yes, I agree! I just don't want a huge rake, but an inch difference is fine.
Re: 72-80 Leaf spring swap, m880 springs [Re: smokes] #1440134
05/31/13 01:37 PM
05/31/13 01:37 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
The block is no bigger than the Halfton block. The axle itself is what will make it a little taller and if the rear leaf from the M880 are used aswell they most likely have a few more leaf being a "Over rated" 3/4 ton. Just toss it together and see how she sits. To much rake plan accordingly
Re: 72-80 Leaf spring swap, m880 springs [Re: 76dodgeboy] #1440135
05/31/13 02:16 PM
05/31/13 02:16 PM
State of Confusion
hp383 Offline
hp383  Offline
State of Confusion
If you want a taller block, use one from a 91-93 Dodge diesel club cab 4x4 they used a factory 6" block, the rest were 4" or 5" i dont recall.
And there are some reports, and pictures, of factory 3" blocks on some models of trucks. I'm not sure what decided the block height on the trucks, it seems to be a mystery.
My Ramcharger has a diesel lift block in the rear, and I used an add-a-leaf to the front to level it out. Sits perfect and easily clears 33" tires on 9x17 wheels.
