Re: What should the compression test #'s be on a 6.1 HE
[Re: None2Slow]
#143963
10/31/08 07:23 PM
10/31/08 07:23 PM
Posts: 1,828 houston texas
gremlinsteve
houston texas
i have never evere ever seen one at 200 psi....
stock that is.
stock 6.1? i have seen 135 as the norm. some a touch higher but not that much.
i have degreed a stock srt8 cam in in the past. ended up 4 degrees advanced and the cranking comp. was raised to 185.
that is the most i have ever seen a 6.1 get to using a stock cam.
with some of my stuff i have done now, i have been able top pull 200-225 and every where in between out of them.
steve-o
if You Like Gremlinsteve. Gremlinsteve Likes You.
