Re: Does it ever end? Another 727 leak
[Re: bobby66]
#143932
10/31/08 03:01 PM
10/31/08 03:01 PM
Posts: 1,568 Omaha, Nebraska
Scott Carl
Omaha, Nebraska
No, it never ends.
At least its not a Turbo-Hydromagical (Chibby) Had a hot lil' '75 Monza once. Neat car, but I could never keep tranny from bleeding. Me thinks it was possesed
[Re: Scott Carl]
#143933
10/31/08 04:54 PM
10/31/08 04:54 PM
Posts: 3,072 Farmland, IN
Ludington1
Farmland, IN
I had constant leaks with my 727 and then it died on me after about 18 months of weekend cruising I finally went to extreme measures... garage floor looks better, my face looks like and my car goes like Darren
[Re: John_Kunkel]
#143936
10/31/08 09:56 PM
10/31/08 09:56 PM
Posts: 4,740 Florida
BDW
The band adjuster isn't a very common leak point. The adjuster is the same size as a 1/2" drain plug washer so you could install one under the nut.
Any adjustment needed, or just remove the nut and add the washer? My tranny has a reverse manual valve body if that makes any difference?
[Re: BDW]
#143937
11/01/08 02:58 PM
11/01/08 02:58 PM
Posts: 25,894 Rio Linda, CA
John_Kunkel
Rio Linda, CA
You could just hold the adjuster and remove the nut to install a washer but why not adjust it while you're at it?
[Re: John_Kunkel]
#143938
11/01/08 03:21 PM
11/01/08 03:21 PM
BDW
Well, that's the problem. I have no idea how to adjust it. Any simple instructions or tips?
Thx
[Re: BDW]
#143944
11/01/08 04:19 PM
11/01/08 04:19 PM
Scott Carl
Omaha, Nebraska
Thx
Isn't this the band adjustment? The specs should be in any Motor's, Chilton's or Haynes manual. It does take an inch pound torque wrench or the conversion to foot pounds. Sorry, I have neither.
[Re: Scott Carl]
#143948
11/01/08 06:13 PM
11/01/08 06:13 PM
Posts: 7,196 Harrisburg, Pa.
screamindriver
Harrisburg, Pa.
Thx
The torque value is just to make sure it's snugged up...A small wrench will do the job...Just snug it down then make your adjustment..
[Re: BDW]
#143949
11/01/08 06:15 PM
11/01/08 06:15 PM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
Wonder which spot will leak next. I've already fixed the following:
Pan gasket Neutral safety switch gasket Pivot pin Selector shaft seal Driveshaft seal
How about the oilfiller tube seal...?
[Re: MoparDonny]
#143951
11/03/08 09:13 AM
11/03/08 09:13 AM
Posts: 15,487 Florida
scratchnfotraction
clean it with brake clean throw some baby powder up on it look to see where its seeping from did you change both shaft/selector seals? does not look like you gots much adjustment left,not many threds showing above the lock nut,may be your last adjustment and hope you can get the lock nut back on may be you should mark it,hold it there and back the lock nut off,use some brake clean to remove the oil,then just put a little rtv (mopar black rtv for trannys)around the case and adjuster and tightend the lock nut back down with the adjuster in the same spot you have it in now thats if its shifting and working good...dont fix what anit broke and like said,the valve body may have its own specs for the band adjustment
