A/C self-servicing
#1438800
05/19/13 01:26 PM
05/19/13 01:26 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang.. I was curious, is there there a setup in which I can charge up my A/C on my '98 Ram 5.9 SS/T. This truck has been awesome and I've NEVER had to repair or touch the a/c system. But, I believe it may be getting low on coolant. So, is there anything I can do myself that will replenish the system? I'm also curious, is there a fault indication of a low-pressure situation? I see there's a servicing port on the passenger side.
Thanks in advance..
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: A/C self-servicing
[Re: hemi68charger]
#1438801
05/19/13 04:37 PM
05/19/13 04:37 PM
Posts: 26,005 Rio Linda, CA
John_Kunkel
Rio Linda, CA
The fitting in the pic is the high-side fitting; charging is done through the low-side fitting below and to the rear of the air cleaner inlet duct.
The only really correct way to charge the system is by weight (the amount is on a decal under the hood) and it helps to have a gauge manifold/hose set (available cheap from Harbor Freight) and the pressures on the gauge set will tell if the charge is low.
With the manifold set you can top off the charge by temperature/pressure but it's not as precise as by weight.
[Re: hemi68charger]
#1438802
05/19/13 04:38 PM
05/19/13 04:38 PM
Posts: 10,570 Sunny South Florida
Golden-Arm
Sunny South Florida
if it's r134, you can get a can and a gauge from any auto parts store. crank it up, turn the air on high connect the gauge and follow the directions. pretty easy and straight forward. they make refrigerant with dye in it, if you think you have a leak, and want to look for it. the can and gauge set costs between 25-40 bucks, depending on brand. once you have the gauge, you can use it on any car with r134 and a new can. fyi, once you install a can on the gauge/filler, it has to stay on, or you must use it all. if you take it off, the remainder of the can will come shooting out, all over the place. ![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Golden-Arm]
#1438803
05/19/13 04:47 PM
05/19/13 04:47 PM
John_Kunkel
Rio Linda, CA
Most refrigerant can tappers have a shutoff valve so you can use part of the can and then shut the valve...problem is most tappers will leak off the remnants in the can in a short time.
[Re: ahy]
#1438807
05/20/13 05:32 PM
05/20/13 05:32 PM
Golden-Arm
Sunny South Florida
this kit does have a gauge on it, just not a fancy one. it displays pounds, and has a color coded sweep around the gauge, showing low, correct and high pressures. for the guy thats going to fill his truck once in a lifetime, it's a good deal. and, you can screw any of the cans onto it. on an r12 ride, i go to an a/c place and give them the refrigerant. the guys here will pull it out, and leave you with a vacuum in the system, so you can go home, add your oil, and add the refrigerant. not a bad deal, really. ![](/ubbthreads/images/graemlins/biggrin.gif)
[Re: hemi68charger]
#1438808
05/20/13 06:17 PM
05/20/13 06:17 PM
Posts: 3,325 Truckville, the capital of NY
85_Ram_4speed
More than likely, the evaporator under the dash in the heater box is leaking. Its a real common problem, and usually when you have the box out, the smart thing to do is do the evap and heater cores at the same time. Its about a 5-10 hour job depending on your experience to swing the dash out of the way to get the box out.
For the moment, try one of the cans as suggested above and see if it fixes it. If you can go all summer and not have to worry about it, then its a small leak. A/C systems are like brake systems, they either leak or they don't. Also, make sure they can you add into the system has dye in it, this will help a technician find the leak later on if you choose to have someone fix it for you---or you can buy a UV light to see yourself where the leak is--unless its in the heater box. No way to see that until its apart.
Also, check the condensor up front to see if it has any staining on it running down it. This would be the oil in the A/C system dripping out. Not uncommon to have road debris puncture it--even slightly.
If its leaking from a hose, sometimes that is harder to find, the dye can help here, and again, look for accumilating dirt clinging to the oil leaking out. There is no warning lights to indicate low A/C refrigerent, a low pressure switch shuts off the compressor if there isn't enough refrigerent and a high pressure switch shuts it down to keep the sytem from self destructing with to much pressure.
Hope that helps some.
Outcast Dodge guy.
[Re: 85_Ram_4speed]
#1438809
05/21/13 03:29 PM
05/21/13 03:29 PM
John_Kunkel
Rio Linda, CA
If a '98 truck is just now low on charge I wouldn't consider it anything but "normal" leakage.
Charging an R134 "by guess and by golly" isn't a good idea, a gauge set and can tapper would be the minimum equipment needed.
