Page 3 of 4 1 2 3 4
Re: Race car trailer tie-downs, what do I need? #14420
02/18/05 08:24 PM
02/18/05 08:24 PM
541 slobovia
A990 Offline
A990  Offline
541 slobovia
Well I searched the M&R site and found the page with the tie down info
http://www.mrproducts.com/combotiebacks.htm
Good post- I need some for a Charger I have to haul, and I'm getting tired of the lame stuff the rental place uses
KG
Re: Race car trailer tie-downs, what do I need? #14421
02/18/05 08:36 PM
02/18/05 08:36 PM
Manheim PA.
mopardad Offline
mopardad  Offline
Manheim PA.
My weakest link is the tie down rings them selves. The straps are not just to hold your car on the trailer, they are also for protecting everyone around you from your cargo.
Having someone go thru a stop sign & hitting them while pulling a car on a trailer I can tell you this, My blue staps became white wherever they went thru a hook or adjuster but were not tore, all the hooks spread open somewhat, the triangular shaped pieces that the hooks snap into were very distorted, the rings on the trailer were not affected, the ball mount on the hitch (the 3/4" thick steel) was bent up pretty bad, the car hardy moved on the trailer
This happened going thru town probably not over 40MPH.
I had 2 axle straps straight forward in the front & 2 rachet straps crossed in the rear.
Re: Race car trailer tie-downs, what do I need? #14422
02/18/05 08:56 PM
02/18/05 08:56 PM
64hemi Offline
64hemi  Offline
Thanks for the suggestion Greg. I went out to the garage and looked at it and I now have a plan.
Re: Race car trailer tie-downs, what do I need? [Re: 64hemi] #14423
02/18/05 09:48 PM
02/18/05 09:48 PM
Down South
CaptNemo Offline
super gas
CaptNemo  Offline
super gas
Down South
Terry, do you have the factory K Member in the car or is it one of the aftermarket racing K's ?
Re: Race car trailer tie-downs, what do I need? #14424
02/18/05 09:50 PM
02/18/05 09:50 PM
Down South
CaptNemo Offline
super gas
CaptNemo  Offline
super gas
Down South
Dave, why do you have to trailer a street car? Just drive it to the track like I do...
>cough cough<
Well, I'm not going to drive my Duster 1,100 miles to the Mopar Nats!!! Plus, I want to trade in my show poodle status and upgrade to trailer queen.
That was meant for James... You see, there's this black thing that follows his truck and transports the red car on top of it...
Re: Race car trailer tie-downs, what do I need? [Re: CaptNemo] #14425
02/18/05 10:55 PM
02/18/05 10:55 PM
64hemi Offline
64hemi  Offline
No it's the stock K-member notched.
Re: Race car trailer tie-downs, what do I need? [Re: 64hemi] #14426
02/18/05 11:33 PM
02/18/05 11:33 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
When I had the stock K-frame I got 2 small axle U-bolts (2 1/2"x 1/2" or so). I drilled 2 holes on the each side edge of the K, then put the U-bolts up through the 2 holes and used 4 nuts to lock the U-bolt in place facing down. Gave me something for the straps to hook to that was solid. Quick fix for stock K frame cars
<Edit> since I never took a pic of where I put the U-bolts, I tried to show it in this pic with the black dots *** see attached ***
Re: Race car trailer tie-downs, what do I need? [Re: 64hemi] #14427
02/19/05 01:15 AM
02/19/05 01:15 AM
Down South
CaptNemo Offline
super gas
CaptNemo  Offline
super gas
Down South
On the K-Member that came out of the '64, I removed the pinch welded section between where the strut rod bushings are and the center of the K-Frame. The idea being not to cause any places for the straps to chafe.
On the '63 I have been running the front straps through the front, outer portion of the K-Frame with a chafe guard on the strap and so far, it looks OK. I brought the car from St. Louis to Chicago, back to St. Louis and then home - about 1800 miles, plus a couple of trips to the track, one to the dyno and one out to SB412DUSTER's shop. No damage on the straps and the car is secure.
I'll have to shoot some photos tommorrow at the track to better illustrate what I'm talking about.
Re: Race car trailer tie-downs, what do I need? #14428
02/19/05 01:46 AM
02/19/05 01:46 AM
Ca Registered: Mar-2001
hemiallen Offline
hemiallen  Offline
I am still fine-tuning our setup on a 16' open trailer. I just got 2 of the trucker style D ring loops and welded them to 6" square 1/4" thk plates, then bolted them through the frame to the front corners of the trailer with grade 8's 1/2" bolts. The stock flush mounted rings seemed wimpy, and weren't far enough out to get a good angle on the straps, probably due to a short trailer and long car ( 66 charger). On the front I am using axle straps and 10k ratchet straps, but am thinking of welding a U-bolt to the bottom of the K member similar to Al on his dart.
On the back I am considering what a friend did on his top fuel car, use 2 axle straps and a chain with a chain hook, slip the chain end thru the strap eyes, thru the bed hook and hook to chain forming a loop, and use the fronts to remove the slack. I also built a removable cable winch ( to keep it out of the weather and theft deterrance- also something to do with the welder that's fun-lol) and I will also use the winch as a backup for tension on the front. I'll snap a picture tomorrow if it doesn't rain.
What do you-all think of the chain on the rear end?
Allen
'05 Quad cab hemi truck- Flame red- magnaflow exhaust 70-440 cuda- 74-360-4v Challenger- new driver car EX vehicles: 66 charger Drag car- 10.80 at 123 mph 57 imperial 392 Hemi 1960 Sanger V drive- mondello-built 392 hemi
Re: Race car trailer tie-downs, what do I need? [Re: hemiallen] #14429
02/19/05 04:24 AM
02/19/05 04:24 AM
Wichita Kansas
B Dartman Offline
B Dartman  Offline
Wichita Kansas
http://www.racerwholesale.com/catalog/index.php?cPath=41_44
Lots of places on-line have what you need....here's some examples..
B Dartman's 71 Dart Swinger in Mopar Muscle (Sold Dec 2021): https://www.hotrod.com/articles/1971-dodge-dart-destiny-determination/
B Dartman's 71 Dart Swinger in Dodge Garage (Sold Dec 2021): https://www.dodgegarage.com/news/article/showcase/2019/04/destiny-determination.html
B Dartman's 71 Dart Swinger early build pictures (Sold Dec 2021): https://s165.photobucket.com/user/Billswild440dart/library/
Re: Race car trailer tie-downs, what do I need? [Re: Bigcube] #14430
02/19/05 09:42 AM
02/19/05 09:42 AM
64hemi Offline
64hemi  Offline
Bigcube you read my mind Bro. That's exactly what I came up with
Re: Race car trailer tie-downs, what do I need? [Re: Bigcube] #14431
02/19/05 10:12 AM
02/19/05 10:12 AM
Falconer, NY
KatFysh Offline
KatFysh  Offline
Falconer, NY
I like the clamp idea. seems like the easiest and cleanest appearing set up. Won't have to worry about wrapping the strap anything up front. I'll have to check mine out and hopefully do this before the motor goes back in.
I'd like to see the removable winch set up. I had also thought about doing this. I have the material set aside at work for it. I've just been waiting to make a post for it. You added it here sooner than I was ready. What size winch do you use. Do you think a 3000 lb ATV winch will be okay if it was used with a doubled up cable?
This sound very similar to what I mentioned earlier. A friend of mine does this also.. I'm going to "notch" my rear dovetail so that I can have the clearence to get closer to hook the straps and have exhaust clearence while loading/unloading. I'll have to figure where to have the rear tie-downs to the trailer after I do that.. I'm thinking the inside corners of the notch.. Is that understandable???
When you decide to quit, THAT is the moment when you would've succeeded..
Re: Race car trailer tie-downs, what do I need? [Re: KatFysh] #14432
03/15/05 07:12 AM
03/15/05 07:12 AM
Anonymous OP
Anonymous OP
I've got E-track in the floor of my trailer. The clips are rated heavy, as well as my straps. I've found if you don't put the e-clip in a certain position[in the track], they bend or worse yet, will come out of the floor. I hook the body from loops welded to the rear frame rails.[top of picture] I also have a ring welded to the k-frame. I don't personally recommend the e-clip system, as I've had 2 cars come loose while transporting. My next trailer will be back to d-rings. My shocks are upside down also.[TOP SECRET!!]Crossing the straps seems to be the problem with e-clips. It puts an angled load on them, causing the problems described above.The adjustability for position is great,but I believe it's just to many movable parts.
1569195-race car-3.jpg (186 downloads)
Re: Race car trailer tie-downs, what do I need? #14433
03/15/05 09:53 AM
03/15/05 09:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
This year I am trying a new tie down system (for me),
air bag under the car,the dragster guys use them,
this is to stop or slow the body movement while its
on the trailer, the suspension see's more wear and
tear on the trailer then it does going down the
track.
I plan on the normal 2 straps in the front, on the
chassis, crossed, then 2 on the rearend, crossed,
air bag under the car at the main hoop area, then
1 more strap pulling down on the body at the rear,
this one will be snug, just so the body wont move
up and down to save the shocks, I have more in my
shocks than the air bag
Re: Race car trailer tie-downs, what do I need? #14434
07/03/05 11:56 AM
07/03/05 11:56 AM
On The Boat, On The Lake, Wa. ...
amxautox Offline
Still Retired. Still Posting on Moparts. A Lot.
amxautox  Offline
btt for a new member to read.
Tom
"Everyone should believe in something; I believe I'll go fishing."
-Henry David Thoreau
Men and fish are alike. They both get into trouble when they open their mouths
author unknown
Re: Race car trailer tie-downs, what do I need? [Re: BENCHRACER] #14435
07/03/05 01:54 PM
07/03/05 01:54 PM
Yorktown VA
motorheadjohn Offline
Ridin' Shotgun
Ridin' Shotgun
Yorktown VA
I towed a car for someone once and the car had hooks welded to the frame that you could just quickly hook on to and go (instead of rapping around the axle or k-frame). I have been wanting to weld hooks of some kind to do the same to mine but someone has told me that it can bend the frame downwards from the bounce of the car going down the road. What do you think?
Bending the frame and/or doing sheet metal damage is a possibility, depending on where the attach points are.
I have a very good friend that bought a 90 Mustang LX coupe on the internet and had it shipped. It had 2 soft-ball sized dents in the quarters, one on each side, when it arrived and the shipping company tried to fake the paperwork to make them look like pre-existing damage. Hice huh? Good thing he had copies of the original shipping paperwork and could prove they altered the delivery copy.
My friend figured it was loading/unloading damage, but when I started looking at the car, I noticed they were at the exact same point each side, at the corner of where the roof pillar meets the quarter panel. I got to looking and concluded they had tied the car down using a hole at the rear bumper on the frame, and tied it down too tightly. The stress caused a KINK in the quarter at the stress point where the roof met the quarter.
Anyway, he took it to a body shop for a repair estimate for the claim against the shipper's insurance, and the body ship confirmed it was damage from impropper tie down.
On a leaf-spring car, the stress points might be different, but on that Mustang (factory 4-link?) tied at the rear of the frame, it caused problems. Just be careful and think about the way the stresses will be applied if you're going to tie down with the frame rails.
Chicks in the mirror
are fatter than they appear
Re: Race car trailer tie-downs, what do I need? [Re: motorheadjohn] #14436
07/05/05 11:45 PM
07/05/05 11:45 PM
amxautox Offline
amxautox  Offline
back to the top for another person to read. Gotta keep this one on the board.
Tom
author unknown
Re: Race car trailer tie-downs, what do I need? [Re: amxautox] #14437
07/04/06 12:22 PM
07/04/06 12:22 PM
amxautox Offline
amxautox  Offline
same same, someone needed to read it, getting close to the end page.
Tom
author unknown
Re: Race car trailer tie-downs, what do I need? [Re: 64hemi] #14438
07/04/06 12:29 PM
07/04/06 12:29 PM
Akron, Ohio
ProSport Offline
ProSport  Offline
Akron, Ohio
I got tired of crawling under the car at all 4 corners to wrestle with axle straps so last Fall I had a D-ring welded to all 4 corners of the car and now I can slap the tie downs on there and ratchet them quickly. Makes it so much easier to go Racing.
Re: Race car trailer tie-downs, what do I need? [Re: ProSport] #14439
07/04/06 02:19 PM
07/04/06 02:19 PM
The Swamp
MegaDart Offline
MegaDart  Offline
The Swamp
$%^&* crap, is this Moparts oldest thread??
To expand on MrP's air bag, having a digger I use one too, but not the $239 version, mine was $12 at WalMart. I use 2 inflatable boat dock bumpers one large under the 4 link and one small under middle of rail, they work awesome!!
Page 3 of 4 1 2 3 4
