Heating and Bending Header pipes? #1437227
05/16/13 03:39 AM
05/16/13 03:39 AM
Modesto CA
BFASTER Offline OP
BFASTER  Offline OP
Modesto CA
Theoretically, if headers get hot enough they will bend pretty easy, right? What temp do they typically reach once 'at temp', and what minumum temp would they need to be to start bending?
I need to "re-bend" my headers close to their pre-accident positions if possible. My daughter and her Civic accidently/indirectly ran into the back of my Super Bee while parked in the garage; shoving my exhaust system forward a bit; the tips moved in about a half inch. Steering linkage now rubs a right downpipe, and the ex pipes hang an inch lower than they used to.
Other than replacing the headers(vintage Hooker Blackjacks, I think)...which as everyone knows is done via engine/tranny R+I...I'm hoping to rectify this problem quickly and inexpensively. Any input?
1969 Dodge Super Bee Hardtop 2007 Nissan Altima 3.5SE
Re: Heating and Bending Header pipes? [Re: BFASTER] #1437228
05/16/13 08:07 AM
05/16/13 08:07 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
Metal needs to be redhot before it will bend more 'easily'.
Do you want to bend the 4 pipes at once?
I don't think you will be able to keep all the pipes redhot at a certain point before you can start pulling.
Also reminder the tubes are thinwall, so they cool fast, but you can also burn through them if heated too much in one area.
But... do you really want to handle a hot flametorch in your enginebay like that?
Re: Heating and Bending Header pipes? [Re: BigBlockMopar] #1437229
05/16/13 10:34 AM
05/16/13 10:34 AM
Ontario, Canada
Stanton Offline
Don't question me!
Stanton  Offline
Don't question me!
Ontario, Canada
It ain't gonna work. Buy new headers.
Re: Heating and Bending Header pipes? [Re: Stanton] #1437230
05/16/13 10:47 AM
05/16/13 10:47 AM
X2 X2 unfortunately. packing a single mandrel tube tight with sand then heating it & bending it to keep it from collapsing works well but that's a different deal from what you got going on
Re: Heating and Bending Header pipes? [Re: RapidRobert] #1437231
05/16/13 10:54 AM
05/16/13 10:54 AM
WI
Dcuda69 Offline
Dcuda69  Offline
WI
My crappy BB A-body headers hung kinda low for my taste, so when I put my 3"/x-pipe on I heated the tubes with a rose bud tip(under car not under hood)stuck a pipe in the collector and managed to move them up.....not a lot but they moved enough to give me a little more ground clearance....maybe 3/4"?
Re: Heating and Bending Header pipes? [Re: Dcuda69] #1437232
05/16/13 12:13 PM
05/16/13 12:13 PM
dogdays Offline
dogdays  Offline
I think this is where you're going and it's worth a try:
Drive the car in a situation where it makes quite a bit of power so the headers get nice and hot.
Put a jack under the collector and jack it up.
I bet it works, just don't get too frantic with the jack or you'll oval the collector.
No use to use a rosebud when you have a 300+ horsepower torch at your right foot!
R.
Re: Heating and Bending Header pipes? [Re: BFASTER] #1437233
05/16/13 12:19 PM
05/16/13 12:19 PM
Phoenix - surface of the sun
nomore65BelvJim Offline
Pull it back into position.
If its the header thats shoved forward put a strap on the collector flange and pull it back with a comealong. GENTLY.
Re: Heating and Bending Header pipes? [Re: nomore65BelvJim] #1437234
05/16/13 04:51 PM
05/16/13 04:51 PM
Harrisburg Pa. 17112
moparmikethree Offline
Jim, I think the only way to do this right is buy new ones. There is no way it would ever be right. Did you ever get it painted yet. Tell the family I said hello. Mike.
Re: Heating and Bending Header pipes? [Re: nomore65BelvJim] #1437235
05/16/13 05:17 PM
05/16/13 05:17 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
I would try this too. Depending on how/where they are bent it could work. Just be prepared to buy new headers before you start.
Kevin
Re: Heating and Bending Header pipes? [Re: Twostick] #1437236
05/17/13 12:10 PM
05/17/13 12:10 PM
dogdays Offline
dogdays  Offline
It'll work better with the header hot.
Even a few hundred degrees is better than nothing.
R.
Re: Heating and Bending Header pipes? [Re: dogdays] #1437237
05/17/13 01:12 PM
05/17/13 01:12 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I'd just ding the pipe that is causing problems. You'll never feel the difference in hp from a little dent. That'll get you back in action for a bunch of years till they rust out or you bottom out too many times.
