On the floats that come in a Edelbrock 1405 and 1406 carburetor how bad are they prone to issues? I seen one video of a out of the box that had a leaking float. Anyways, I am asking because I had my carburetor apart today because it smells of strong fuel so I was checking the float level and while I was I doing that I decided to remove the floats to see if they were leaking. Well, I didn't see anything abnormal. However, my one float if you shake it sounds like it has a piece of metal inside but, the other float is fine. Just wondering if anyone has encountered this issue.
