73-76 A body 340/360 Left motor mount #143461
10/30/08 10:31 AM
10/30/08 10:31 AM
Marion,Indiana
Seth_Jones Offline OP
Marion,Indiana
Is the left motor mount reproduced for this combo?
Re: 73-76 A body 340/360 Left motor mount [Re: Seth_Jones] #143462
10/31/08 10:00 AM
10/31/08 10:00 AM
wv
Dartcuda Offline
Dartcuda  Offline
wv
You can still buy the complete mount with the insert from your local auto parts store . Left-2325 , Right-2326 . Advance auto about $25 each.
Re: 73-76 A body 340/360 Left motor mount [Re: Dartcuda] #143463
10/31/08 10:41 AM
10/31/08 10:41 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
You sure that left side part number is different than the 318 part number? It should be.
I thought you couldn't get it, but you could use some washers or a spacer to use the 318 mount.
Re: 73-76 A body 340/360 Left motor mount [Re: autoxcuda] #143464
10/31/08 01:18 PM
10/31/08 01:18 PM
wv
Dartcuda Offline
Dartcuda  Offline
wv
You are correct , my bad . That is for the 318 mount which will work on a 360 with washers or a spacer.
