Standard cab long box to Clubcab shortbox?? #1431885
05/07/13 06:50 PM
05/07/13 06:50 PM
Iowa
76dodgeboy Offline OP
Iowa
Is this possible using the std cab lb frame? I can bob the rear of the frame behind the wheels just wondering if its possible? I have a Std cab lb plow truck and Im getting a clubcab roller from a member. I intend to use that cab on my wifes truck do to rust front mice above the door opening BUT the cab is good enough for my plow truck so I figured I could Swap the cab over and possibly use a Short bed front my clubcab that Im swapping to a stepside. Thanks
Re: Standard cab long box to Clubcab shortbox?? [Re: 76dodgeboy] #1431886
05/08/13 01:09 AM
05/08/13 01:09 AM
Coeur d Alene, Idaho
jimbob101 Offline
jimbob101  Offline
Sounds like alotta work for plow truck!
_j
Re: Standard cab long box to Clubcab shortbox?? [Re: jimbob101] #1431887
05/08/13 02:42 AM
05/08/13 02:42 AM
Iowa
Iowa
Not to me
Re: Standard cab long box to Clubcab shortbox?? [Re: 76dodgeboy] #1431888
05/08/13 08:08 PM
05/08/13 08:08 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
I'm sure you can. It all comes down to moving the cab mounts. And I believe the cross member behind the cab is in a different location. But you have both frames to measure, correct?
Re: Standard cab long box to Clubcab shortbox?? [Re: 76dodgeboy] #1431889
05/08/13 10:17 PM
05/08/13 10:17 PM
Greensburg, Pa
Mpetros Offline
Mpetros  Offline
Greensburg, Pa
2" Difference in Wheelbase..
Standard Cab 8' Bed 131" WB
Club Cab short Bed 133" WB
Re: Standard cab long box to Clubcab shortbox?? [Re: Mpetros] #1431890
05/08/13 10:23 PM
05/08/13 10:23 PM
Iowa
Iowa
Yeah I found a chart. I just might swap them. 2" gap don't bother me none
Re: Standard cab long box to Clubcab shortbox?? [Re: 76dodgeboy] #1431891
05/08/13 11:16 PM
05/08/13 11:16 PM
Jerseyville Il.
syco Offline
syco  Offline
Jerseyville Il.
The rise in the frame is in a different location on the reg cab. Its the same issue with putting a crew cab short bed on a club cab long bed frame or a reg cab on a ramcharger frame. You either have to use a body lift or channel the cab for the hump.
Re: Standard cab long box to Clubcab shortbox?? [Re: syco] #1431892
05/08/13 11:26 PM
05/08/13 11:26 PM
Iowa
Iowa
Bodye lift Won't be of much use when the rear cab mount needs moved any way. the rise is in the same spot its behind it were the frame is made longer
Re: Standard cab long box to Clubcab shortbox?? [Re: 76dodgeboy] #1431893
05/08/13 11:28 PM
05/08/13 11:28 PM
Iowa
Iowa
Frame
