First time post, long time lurker...
Ok i'm finally building my cruiser a 1976 New Yorker coupe . The 440 was cleaned up at the machine shop and the bore is stock as there was no need to open it up. I was going to just slap it back together with a little hotter cam and a small converter and mill the heads. But after searching the forums that looks like an expensive way to get compression.
I found these 6 pack pistons on EBAY for 350$
EBAY LINK 440 Pistons My question is will these work with the stock rods in my 76'? I'm offshore right now and have no access to the pistons and rods that came out of it.
The goal is to have an engine with a bunch of torque, and a good sound... It will have 2 chamber flows dumped over the axle when all is said and done. The Cam is a elcheapo summit grind
Summit K6401 .
I'm going to home port the heads a little and install new springs and lap the old vavles in good... Heads are 452's and the compression should be in the 9.3 range with the above mentioned pistons.
Any opinions on what i need to look for. This is my first 440 since high school shop class..
Thanks Jay
