Dakota problem #1431078
05/06/13 03:28 AM
05/06/13 03:28 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
I have a 96 with 318 . My cruise control sticks on sometimes..
As in , i tap the brakes and it wont shut off--the engine accelerates / throttle goes to the floor !! I basically have to stand on the brakes--and hold down the SET button.
Once i had to put it in neutral and shut the engine off !
If i press the on/off button, it wont shut off.
It does this randomly, i have changed out the control button deal thats on the steering wheel.
What would cause this ???
Re: Dakota problem [Re: 493_DART] #1431079
05/06/13 07:29 AM
05/06/13 07:29 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
sounds like the cruise control servo/control unit as gone bad
**Photobucket sucks**
Re: Dakota problem [Re: 70Cuda383] #1431080
05/06/13 10:51 PM
05/06/13 10:51 PM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
where is that located sir--and whats it look like
Re: Dakota problem [Re: 493_DART] #1431081
05/06/13 11:42 PM
05/06/13 11:42 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
It is most likely the clockspring control located under the steering wheel.
If yours is the same as the 92-93 I have two good used ones.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Dakota problem [Re: hp383] #1431082
05/07/13 12:40 AM
05/07/13 12:40 AM
Worst Weather USA
493_DART Offline OP
493_DART  Offline OP
Worst Weather USA
I replaced the clockspring a couple years ago with a good one.
Re: Dakota problem [Re: 493_DART] #1431083
05/07/13 12:51 AM
05/07/13 12:51 AM
Kings Beach, CA
tahoechallenge Offline
Kings Beach, CA
My 92 would sometimes stick. The cable going from the throttle body to the vacuum actuator would stick. Spraying wd40 on the cable would fix it for a while.
