Drum brake problem driving me nuts!
#1430862
05/05/13 09:15 PM
05/05/13 09:15 PM
Posts: 754 Pennsylvania
67DeLuxe
Pennsylvania
I have been chasing this problem now for 2 weeks. 1961 Dodge Phoenix with manual drums all around (yes, I know I should just do a disc conversion.) New single reservoir master cylinder, new wheels cylinders front and back, soft lines all look brand new. When you first start out driving the car you have nice pedal feel and car is rolling along great. After driving for 30 minutes or so around town the pedal becomes harder and harder. Eventually you can feel the brakes starting to grab ( rears, not fronts). Today when this happened I hurried up and jacked the back end up when i got home. Wheels were practically locked up. I could barely turn them and wheels were HOT. Cracked the bleeders open and fluid shot out like a firehose. Wheel cylinders released, wheels spun freely. This pressure will release on it's own eventually too because once the I stop driving the car for a few hours the wheels free up on their own. I have replaced the obvious, checked the obvious, bled properly, etc etc. Front wheels no problem, back wheels driving me nuts. What would cause pressure to build in the rear wheel cylinders while driving enough to cause the shoes to grab. And why does the pressure dissipate after it sits for a few hours? What am I missing here. I am no drum brake genius but there are only so many things it could be. I have even considered that the fluid may be getting heated up somehow but I don't see anything obvious with the routing of the brake lines. Any ideas, guys?
Re: Drum brake problem driving me nuts!
[Re: 67DeLuxe]
#1430863
05/05/13 09:19 PM
05/05/13 09:19 PM
Posts: 20,217 Park Forest, IL
slantzilla
Park Forest, IL
Did you replace the rubber hose in the rear? It may look good but be delaminated inside and holding fluid pressure.
Had one on a Dart do it that looked brand new on the outside.
[Re: 67DeLuxe]
#1430865
05/05/13 10:57 PM
05/05/13 10:57 PM
RapidRobert
X3 if both rear corners are locked/hot. If only 1 side then I'd do a good visual behind that drum & if all kosher then replace the wheel cyl & bleed it out.
[Re: DoctorDiff]
#1430868
05/05/13 11:20 PM
05/05/13 11:20 PM
RapidRobert
I think the Doc nailed it ![](/ubbthreads/images/graemlins/bow.gif) . I forgot about the adjustable pushrod on the early manual brake apps
[Re: 1_WILD_RT]
#1430870
05/05/13 11:31 PM
05/05/13 11:31 PM
67DeLuxe
Pennsylvania
Have not checked the pushrod length either. Will check that too. Good tip
[Re: 67DeLuxe]
#1430871
05/06/13 12:00 AM
05/06/13 12:00 AM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Easy way to check it is to drive it ill the brakes start dragging the loosen the nuts holding the M/C a couple turns, if the brakes release you know whats happening....
[Re: 67DeLuxe]
#1430877
05/07/13 11:36 AM
05/07/13 11:36 AM
Posts: 1,179 Canada
demon
Canada
Here's a suggestion, should you decide to upgrade the brakes. I drIve a 61 Plymouth. I wasn't a fan of the original total contact brakes And single master cylinder so I swapped all the brakes off a 64 New Yorker ( I also used the spindles and front sway bar from the 64). Now I have 11x3 Bendix brakes. I have a newer 8 3/4 so no tapered axles either. I also used a new dual master cylinder and a brake divider block from a 67 New Yorker. Total bolt on and stops fantastic. Another option for upgrading is discs off a Volare/Aspen/5th Ave/Diplomat will bolt right on. Use the spindles, brake divider from the newer car too and it's easy
[Re: demon]
#1430880
05/09/13 08:22 PM
05/09/13 08:22 PM
Posts: 2,537 God's Country Maryland
GODSCOUNTRY340
With a single pot master and only the rears are locking you most likely have a bad rear brake hose or bad proportioning valve. I'd say the rear hose is bad. Next time it does it disconnect the metal line before the rear hose to see if it relieves the pressure. If it doesn't your hose is bad. If it relieves the pressure the problem is before the hose.
[Re: GODSCOUNTRY340]
#1430881
05/10/13 12:43 AM
05/10/13 12:43 AM
Posts: 21,085 Niles , Ohio
therocks
Niles , Ohio
There is no PP valve on drum brakes.That system just has a line to the back from the splitter.Its probably the hose if the cylinders are good.We used a 69 C body rear in my kids 62 300.Almost fit perfect.Then he scrounged my spare 65 B body rear and it did fit perfect.Rocky
Chrysler Firepower
