MSD Blaster 2 coil. Use the supplied resistor? #1430720
05/05/13 05:23 PM
05/05/13 05:23 PM
Canada
demon Offline OP
demon  Offline OP
Canada
I am going to install a new MSD Blaster 2 coil on a B body. It has a Mopar Performance electronic ignition conversion with the 4 post ballast resistor. I know the green with red wire does nothing on the 4 pin orange control box.
Should I just eliminate the 4 post ballast resistor and use the MSD resistor instead?
Re: MSD Blaster 2 coil. Use the supplied resistor? [Re: demon] #1430721
05/05/13 07:00 PM
05/05/13 07:00 PM
I was thinking someone the other day said the MSD recommended ballast is 0.8 ohms? I'd start by ohming the coil half of the 4 terminal ballast & see what you get & you can add a blue wire loop at the brown wire end just like there is at the other end to make it a parallel circuit which will drop the resistance even further if need be. On one I had it had 1.6 ohms on the coil side (way too much) and 6 ohms on the other side & after making them parallel I got 1.1 ohms which was close enough for my app plus keeping the 4 terminal ballast in the 4 terminal harness keeps a clean look & you can actualy sub in 2 singles as their width together side by side is the same as the 4 terminal ballast so you can mix & match plus parallel bypass if needed to get the ohms you want.
