Headlight problem on 01 1500 #1429980
05/03/13 10:39 PM
05/03/13 10:39 PM
Jerseyville Il.
syco Offline OP
syco  Offline OP
Jerseyville Il.
2001 ram 318 4x4 loaded. Low beams only work when tilt column is all the way up. High beams work in all positions. Fog lights also work. Could it be the turn signal/high beam switch? A ground? Frayed wire? Any suggestions.
Re: Headlight problem on 01 1500 [Re: syco] #1429981
05/03/13 11:00 PM
05/03/13 11:00 PM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
yes to all of the above. pull the switch and test it for continuity in all positions. if it's good, pull the harness, and look for damage. checking dash ground, and column ground is a safe bet, before you start pulling parts.
Re: Headlight problem on 01 1500 [Re: syco] #1429982
05/04/13 12:44 AM
05/04/13 12:44 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
pull the plastic column covers, inspect the wiring connector. You'll find a wire broken or pin pulled out. You owe me a beer if I'm right
