How do you test an alternator?
#142595
10/28/08 02:42 PM
10/28/08 02:42 PM
Posts: 803 Zebulon
Stationwagonguy
A Closet Buick Man
A Closet Buick Man
Zebulon
I have a '78 Impala, just got it running again after it sat for almost 15 years. Anyhow, the "generator" light is on on the dash, and I'm trying to figure out what the issue is. The battery will obviously take some charge, but not an awful lot. I haven't actually had a chance to fully charge it either, but it took a jump pack to get it running and after running a half hour (mostly at idle), when it stalled out, I had to jump it to start it again. It would only crank about one revolution then give up. However, all the lights seemed to still work fine.
I don't know- I'm guessing since the generator light is on, it's either the alternator or the battery. How do I test either to be sure if either are good or bad? I'd rather troubleshoot than just throw money at it.
I do have a multimeter, but I'm not that good with it.
Thanks!
[image][/image]
Bob
SWG
'68 Chrysler Town & Country, 'Katy Jo'
'70 Chrysler 300 2-door
'78 Impala 2-door
Re: How do you test an alternator?
[Re: Stationwagonguy]
#142596
10/28/08 02:50 PM
10/28/08 02:50 PM
Posts: 15,487 Florida
scratchnfotraction
take the hot wire off the batt while it is running....if it shuts off the alt is bad if it stays running its a low or bad batt use the multi meter to check for 14 volts while its running at the batt...may be a little more than that if its got a low batt and the alt is chargeing at the time of the reading have the alt tested at a parts store before replacing it to be sure good luck....
[Re: scratchnfotraction]
#142597
10/28/08 02:54 PM
10/28/08 02:54 PM
Posts: 21,843 Kirkland, Washington
Pacnorthcuda
Don't do this, not only is it an unreliable test of an alternator, it can damage other components when the battery is removed from the system. The battery serves as a cushion to protect against spikes.
[Re: Pacnorthcuda]
#142598
10/28/08 03:38 PM
10/28/08 03:38 PM
Posts: 3,533 Indiana
Fury Fan
Indiana
When the alternator is spinning try touching a screwdriver blade to the bearing cap on the rear of the alternator (if it has one, Mopar alternators are configured like this). Be cautious of hitting any wire terminals to ground, though.
If you get magnetism, the alternator is doing something (although you don't know how much output it has) but could still be a culprit. If there is no magnetism, though, the alt is not doing anything.
This tip is more of a first-strike diagnosis and is NOT the full story.
Parts I seek:
driver doorpanel, 65 Sport Fury, prefer black, needs to be 7-8 on 10 scale, might buy set
16" x 6" Dodge truck wheel(s), from early 70s?, takes 9" dogdish - need for a research job so cheaper is better.
69-73 C-body caliper brackets and/or splashields
Send a PM.
[Re: Pacnorthcuda]
#142599
10/28/08 03:43 PM
10/28/08 03:43 PM
i disagree. its not the best test but it would work. and these cars are pretty stout when it comes to electronics susceptable to voltage spikes.
If youre really concerned, then dont reconnect the battery if the car stays running with the ignition on. have someone turn off the ignition before reconnecting it. then there will be no spike so no possible damage
but a voltmeter would be best. check battery voltage at the alt outpput with the car off and then with it running. voltage should be a few volts higher with the car running
#142600
10/28/08 03:51 PM
10/28/08 03:51 PM
Pacnorthcuda
So if you disco the battery from a running car and the car dies you figure you just reliably determined that the alternator is bad? Really?
#142602
10/28/08 04:22 PM
10/28/08 04:22 PM
i guess I should have said it was a good test for the charging system.
mind you, this is for people who are just looking for an easy way to check battery or something else. I have a meter and know how to do it. Im just tired or rewriting it again and again
#142605
10/28/08 08:43 PM
10/28/08 08:43 PM
!!! DO NOT EVER DO THIS !!!
I've actually checked this years ago with a "test pig" that had no electronic anything. Disconnecting a charging unit from the battery generates OVER A HUNDRED volts of spike. I don't have it anymore, but I once had a 'scope photo of this spike, and used to haul it out for guys like you
One modern cars, with electronics of all kinds, solid state controls, radios, regulators and ignition, this is a GUARANTEED way of frying something. Yep---I know you "got away with it"---you might get by over a hundred times, and the 103rd time you do it, "the guy" might say, "Ya know, it's funny, when YOU worked on my alternator 'thu udder day' the RADIO quit working."
#142607
10/28/08 10:49 PM
10/28/08 10:49 PM
Posts: 5,033 Ontario
5537SG
super gas
super gas
Ontario
Disconnecting the battery on any vehicle while the vehicle is running is nothing but stupid. Its just as you say, it generates a huge spike, thats capable of serious damage. Oh, it might not be immediate, but it damaged something!
Ya know, I argued back and forth with a few know-it-all hacks here a few years ago over this very topic. Some people just dont want to learn.
The good news is most people get away with it because their alternator is actually bad (disconnecting it also can damage it too) and there is no spike. However, if its working....its a different story.
[Re: 5537SG]
#142609
10/28/08 11:42 PM
10/28/08 11:42 PM
Posts: 4,956 WI
Dcuda69
WI
Besides taking the chance of creating a spark near the batt.It's obvious some people have never seen a battery explode,not pretty!! If you have a Batteries Plus or even Auto Zone should test it for you,or follow the instructions above and use your meter!!!
[Re: RodStRace]
#142612
10/29/08 09:28 AM
10/29/08 09:28 AM
Posts: 1,822 Colorado
denfireguy
Colorado
I wrote a long version a month ago, and don't want to again. Here you go. There are others on the net, too. http://autorepair.about.com/od/electricaltroubleshooting/a/battery_check.htm
You are right, thought we had beaten this horse to death already. No wonder there are so many bad regulators on the rallye dashes out there. Craig
2014 Ram 1500 Laramie, 73 Cuda Previous mopars: 62 Valiant, 65 Fury III, 68 Fury III, 72 Satellite, 74 Satellite, 89 Acclaim, 98 Caravan, 2003 Durango Only previous Non-Mopar: Schwinn Tornado
[Re: stumpy]
#142613
10/29/08 09:45 AM
10/29/08 09:45 AM
5537SG
super gas
super gas
Ontario
Guess I've been lucky for the last 50 years. I never had one spike enough to hurt the electrical system or a battery blow up either. But we must listen to the "experts".
sometimes the damage isnt obvious or immediately apparent.
I dumped alot of Freon into the atmosphere too, but I never saw anything happen
As for the blown up battery, tell that to the guy at the garage down the road from me with one eye. It does happen.
But theres no need to be cranky about it, just accept the new found knowledge and move on. The day a mechanic stops learning is the day they are no longer a mechanic.
Keep an open mind, and aim to learn, cause it never stops.
the guy who started this thread sought knowledge, now he has some.
[Re: ahy]
#142614
10/29/08 09:50 AM
10/29/08 09:50 AM
Posts: 233 NH
Fastback67
NH
if you take the alternator off, Autozone will test it for free.
Most shops will test it for FREE
