Factory choke work with a blocked Exhaust Cross Over?
#1425649
04/25/13 11:46 PM
04/25/13 11:46 PM
Posts: 352 Arizona
69rrgrabber
Arizona
1969 440 motor with factory style choke in the intake housing. I was going to block off the exhaust crossover to help avoid fuel perculation, which always seems to be a problem for me despite the other fixes. Will my choke still work? I'm in Southern Arizona. Winter night temps average in the mid 30s, but usually mid 40s is the worse I will see. Going to an eletric choke is not an option. Thanks!
"It takes a Mopar to catch a Mopar!"
1969 Charger R/T 440
1969 Road Runner 383
1970 Cuda 440
Re: Factory choke work with a blocked Exhaust Cross Over?
[Re: JohnRR]
#1425651
04/26/13 12:08 AM
04/26/13 12:08 AM
Posts: 352 Arizona
69rrgrabber
Arizona
Ok, guess I'll leave it open.
1970 Cuda 440
[Re: dOoC]
#1425653
04/26/13 12:19 AM
04/26/13 12:19 AM
Posts: 352 Arizona
69rrgrabber
Arizona
That was my plan, I may just experiment with it. But I like a choke!
1970 Cuda 440
[Re: dOoC]
#1425655
04/26/13 01:40 AM
04/26/13 01:40 AM
Posts: 1,106 Northeast
VincentVega
Northeast
you're talking about a well-type choke? the later ones have electric assist, but I don't know if that's enough to work it all by itself. maybe you could try one and see but yeah, no crossover, no choke action unless you do something fancy FWIW I had the AFB 4 bbl from a 273 on my slant six, which was full-on electric choke in the can hanging off the side of the carb. never had any problems with it. now the loose rods were a problem... but those certainly couldn't be related to the 4 bl manual choke is always an option
Looking for 1975 through 1978 B body 4 door sedan sheet metal or parts cars - monaco, fury, coronet. Please let me know
[Re: 69rrgrabber]
#1425656
04/26/13 02:31 AM
04/26/13 02:31 AM
Posts: 9,100 Rogue River, OR
Jeremiah
Rogue River, OR
Thanks!
It might work if you are at a high enough elevation. I was able to wind (or was it unwind) my thermo spring to make it open a little sooner which was also aided by the fact that at 4200 ft above sea level the choke setting is way lean to begin with. I still ended up going electric choke because it took longer than necessary to fully open. You could play around with it and most likely get it to work but you will have to be gentle when it's cold.
[Re: Jeremiah]
#1425657
04/26/13 04:10 AM
04/26/13 04:10 AM
Posts: 352 Arizona
69rrgrabber
Arizona
Yes, its the well choke. I'm at 3900 feet. One one of my cars I did go with the electric which works flawless, but with this car I really want it to look stock, course frustration can bring about compromise. I'll play around with the spring and rod length and maybe even drill a hole in the block off before I give up.
1970 Cuda 440
[Re: ScottSmith_Harms]
#1425659
04/26/13 10:39 AM
04/26/13 10:39 AM
VincentVega
Northeast
Looking back at your original problem, avoiding percolation or vapor lock or whatever is going on, maybe it is not a good idea to try to solve one problem by creating another (choke) First and easy - is the fuel line insulated? If not, that can make a huge difference. Is the filter or any part of the line real close to the exhaust system? Gotta move it if so Is the fuel tank venting system working correctly? Old lines, rust, etc... can be a headache. Open the fuel tank filler when it does this and see if you get a huge rush of vacuum or pressure Make sure the bowl vent on the carb is working properly - you want those vapors that build up when sitting to be able to get out try the phenolic spacer - http://www.edelblog.com/tech-tips/resolving-heat-soakp.s. we have made tons of custom length choke rods out of simple aluminum rod. I forget now what dia we used, but it was probably 1/8". it's also a trial and error thing when adding carb spacing in addition to tuning the spring rate, but you can always make it too long and then bend some extra angles into it to shorten it up. and if you're real keen on factory look, once you dial in the right length, just make a new one directly that size
[Re: VincentVega]
#1425663
04/30/13 12:04 AM
04/30/13 12:04 AM
Posts: 352 Arizona
69rrgrabber
Arizona
That is a trick set up on the 6 Pack choke! I may go that route.
So a good point was brought up about focusing on the fuel peculation problem. Well, that's on another 440 but I'm worried having the same problem with this 440 which will go in another car. So I've changed the carb and put a new, Summit 750 Holly designed aluminum, which runs great. Starts great all the time except when I go to hot start it with in say 45 minutes after shutting it off. In trying to fix the problem I isolated the fuel line so that it does not touch the block or other engine accessories, added a plastic spacer, blocked the heat cross over and went to an aluminum intake in hopes of dissipating heat.
What do you suggest I use to insulate the fuel line?
My next move is to install factory valve covers so that I can hook up the gas tank vent to the valve cover breather (70 cuda 3 nipple breather). Maybe add the 440 vapor seperator that goes along with the fuel filter. Last is to buy a heavy, non aluminum carb. But I will try a carb shield.
Thanks!
1970 Cuda 440
[Re: JohnRR]
#1425665
04/30/13 03:35 AM
04/30/13 03:35 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
My manifold heat crossover is blocked plus i have a 1/2" 4 hole spacer under the stock AVS and on start up i pump the pedal 3 times this closes the choke and sets the fast idle it starts fine choke opens fully on start up via the choke pull off, and it stays on high idle till i decide to kick it off. Of course the rod from the choke t-stat is adjusted to not engage. I live in Chicago and have no problems on colder fall nights.
