383 running rough
#1425614
04/25/13 10:44 PM
04/25/13 10:44 PM
Posts: 1,960 Kenosha, Wi
GOLDMYN
Kenosha, Wi
Hi, I've got a stock 383 which was rebuilt when I bought the car. It has what I would decribe as "lean surge" symptoms when crusing and at idle it has a miss. When I nail it the car run very good. I have changed 2 carbs which have had the metering rods changed. What other conditions would make the same symptons?, I've been told perhaps intake manifold gasket? I appreciate your comments.
Semper Fi
Re: 383 running rough
[Re: GOLDMYN]
#1425615
04/25/13 10:51 PM
04/25/13 10:51 PM
RapidRobert
cap the vacuum advance & retry it (timing/rotor phasing). Remove the metering rod springs & retry it. What's the initial and total timing? do the idle mixture screws have any effect?. What idle RPM?
[Re: RapidRobert]
#1425616
04/25/13 11:17 PM
04/25/13 11:17 PM
Posts: 259 Khemi, Stygia
Mebsuta
Khemi, Stygia
I agree. Too much vacuum advance will make it stumble at cruise. Do you have one of those adjustable vacuum canisters on the distributor? Somebody may have been fiddling with it and dialed in too much too soon.
68 Roadrunner. 383 4-spd. Beat up.
[Re: JohnRR]
#1425618
04/26/13 08:51 AM
04/26/13 08:51 AM
GOLDMYN
Kenosha, Wi
MP ignition w/vac capped, Both carbs are rebuilt and one is carter 750 avs and other is carter 625 avs, vacumn is a flutting 15 at idle, to hear the car run, it sounds like running on 6 cylinders, but again, when going throught the gears, the car screams?
Semper Fi
