chassis gurus!!!
#1425283
04/25/13 11:48 AM
04/25/13 11:48 AM
Posts: 5,080 organ
maximum entropy
organ
my buddy got a nice chassis car, and he's gonna run it for the first time on saturday. he scaled it, and it was heavy on the left rear corner. shouldn't it be the right rear? it's a four link car. idk if he has a roll bar- i assume he does.
Re: chassis gurus!!!
[Re: rickseeman]
#1425285
04/25/13 11:55 AM
04/25/13 11:55 AM
Posts: 5,080 organ
maximum entropy
organ
interesting. i thought the left rear gets planted. is that in a leaf spring car only?
[Re: maximum entropy]
#1425286
04/25/13 11:58 AM
04/25/13 11:58 AM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
Well, a chassis car is normally coilovers. The driver sits on the left. The engine is in the front. So the right rear has the least weight on it.
2011 Drag Pak Challenger
#1425287
04/25/13 12:05 PM
04/25/13 12:05 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I disagree.. but you have to base the weights on how much torque the car has.. any chassis car I have seen wanted the RR a bit heavier as in 10 to 30 lbs... but I would start out at zero and if it goes to the right on the launch I would add weight to the RR by shortening the upper right bar a 1/4 turn at a time
[Re: rickseeman]
#1425288
04/25/13 12:06 PM
04/25/13 12:06 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
Generally the right would get the preload making the right side have more weight...BUT...some cars like to be set up neutral and some..like mine.. like negative preload. I set the anti-roll up neutral and make the adjustments with the 4-link. Some people use the anti-roll for preload also.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: Eric]
#1425291
04/25/13 12:10 PM
04/25/13 12:10 PM
MR_P_BODY
I keep the anti roll at neutral all the time.. I load it with the upper right bar(or negative if needed)
[Re: MR_P_BODY]
#1425292
04/25/13 12:27 PM
04/25/13 12:27 PM
Posts: 5,080 organ
maximum entropy
organ
sounds like there is no set rule- start neutral, and adjust as necessary? neutral with the driver in the car? or without? please pardon my ignorance, but i've raced nothing but leaf spring cars.
#1425293
04/25/13 12:59 PM
04/25/13 12:59 PM
rickseeman
Stuttgart, Arkansas
Start with neutral with the driver in the car. Fuel. Race air pressure in tires. -2 degrees pinion angle. Ready to make a pass. No preload. Horsepower will dictate if you need preload. Buy Jerry Bickel's book and Rick Jones book. Best money you can spend if you want to learn about chassis cars.
#1425294
04/25/13 01:03 PM
04/25/13 01:03 PM
Posts: 684 St. Charles, MO.
Slingshot383
St. Charles, MO.
Car needs to be on the scales just like it would be on the starting line, fuel, water, oil, driver (fully suited up), air pressure in the tires set. Set everything neutral and square (distances, front to back, and left. front to .r rear, and r. front to left rear) for the start, and adjust from there.
1994 Undercover Chassis 125" altered
stack injected big block, soon blown and injected
Member of The Torque and Recoil Club
#1425295
04/25/13 02:46 PM
04/25/13 02:46 PM
MR_P_BODY
No there is no set rule as to pre load... that is determined on which way the car goes on launch... and that means at the line to maybe 50-60 ft out... really anything beyond that can be alignment or brakes or other factors.. like Erics car likes a touch of negative pre load, my car likes about 10# of +pre load.. so you get the idea.. and once you take the play out of the bar (upper right) it doesnt usually take much unless something is wrong... all this is based on the zero of the car at race weight... Note... if you go to square up the car like slingshot said make sure what the front end is.. my car has 3/4" of stagger built into the front end(right tire is set back 3/4" to give me a longer roll out) and a lot of chassis shops do the same thing
[Re: Slingshot383]
#1425296
04/25/13 03:03 PM
04/25/13 03:03 PM
rickseeman
Stuttgart, Arkansas
Hopefully the car will go straight the way it is already set up. My car is 150 lbs heavier on the left front than the right rear. Do I care? No. All I care about is if it goes straight when I let go of the button. And it does. I have some buddies that think you are supposed to put it on scales and crank the preload into it until it has the same weight on the rear wheels. I don't know why. There are experts somewhere who could take your wheel weights and horsepower and set the car preload before you go to the track but they don't live next door to you, so you have to learn this yourself. Set your 4-link heim joints up where the left hand thread joints are in the front. You didn't say how much horsepower you have, lets say you have 800. If you set it up with no preload it will probably drift to the right after the launch. Put a half a flat of preload in it and make another hit. Keep working it until it goes straight, then life will be good.
[Re: rickseeman]
#1425298
04/25/13 06:58 PM
04/25/13 06:58 PM
Posts: 1,596 BX, CT, FL.
B1KILLER
BX, CT, FL.
That would work for me
#1425303
04/26/13 09:44 AM
04/26/13 09:44 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
As I understand it, there are two places that twisting forces come from that load or unoad each rear tire at the hit. The one that can't be changed is engine torque against the chassis. You can see it on a top fuel car on launch. The other is the twisting force produced by the instant center of the chassis components. The second one can be anywhere from mild to wild depending on the setup of the chassis combined with the starting line torque available to act on it. IMHO the best setup is just enough preload to counteract the first force at the hit, and use an anti roll device to counter the suspension forces. Any preload that is in the car will also be there down track, which can affect handling and traction. What I have seen on my ladderbar car is if I go to the front mounting hole at the neutral line, on the hit the left bar will gain leverage over the right bar because of chassis roll induced by engine torque at the instant of the hit. The problem builds on itself instantly, because as the car roll rotates the left bar instant center gains leverage, and the right one loses it. I have had my car literally leave on one tire because the twisting got so violent the left rear suspension ran out of travel and the tire came off the track. A fourlink car could also get this messed up if it is set up wrong, because it is so much more adjustable. On a fourlink car, these forces can be reduced by moving the instant center away from the neutral line and moving it further forward to reduce leverage. Most ladderbar cars never experience this problem to the severity that I did because the instant center is high enough to not let the twisting get out of hand before the shocks and springs can stop the suspension movement. But if you try and put 850 + hp through a set of 30 inch ladderbars things can happen quickly. The photo shows chassis twist before the anti roll, and before I got it totally screwed up!
[Re: gregsdart]
#1425305
04/26/13 11:52 AM
04/26/13 11:52 AM
Quicktree
I built an anti roll bar, and the twist you see in the bar is after one pass. The tube is 1 1/8 by .125. I went to 1 3/4 by .134 and it can't hurt that one!
if mild steel try CM
[Re: Cab_Burge]
#1425306
04/26/13 12:27 PM
04/26/13 12:27 PM
rickseeman
Stuttgart, Arkansas
I'm in a similar situtaion as Carls freind, new to me, tube chassis car and no good chassis books in my poccession, yet. Not to hijack this tread but when you guys use the word "negative" or "positive" preload would you please explain which bar and which way to adjust it to get that and what to look for on a scale when adjusting it those two ways
As Mr P Body said, preload is in the top passenger side bar. Let's forget for a moment about positive and negative, shorten and lengthen, that stuff is too complicated, you will learn about that in the books you are about to order. Let's forget about the scales, you just want the car to go straight. A normal chassis car, with under 1000 hp, set up neutral, is probably going to pull to the right. (It is asking for positive preload but that doesn't matter.) If your 4 link bars are in where the left hand heims are to the front, this is easier. Imagine using the top passenger bar as a steering wheel. If it is drifting to the right, you will be turning the top right bar to the left to bring it back. Put a piece of masking tape on the bottom of the bar. Take a magic marker and draw a line on the masking tape. Loosen the jam nuts. Turn the top bar the same way you would turn it if it was the steering wheel to bring it back to the left. Turn it 1/2 a flat. (Thirty degrees, 1/12 of a turn). Lock the jam nuts. Now make another hit. It should not be going to the left as bad. Keep adjusting until it goes straight. Steer with the top right bar. (If you have alot more than 1000 hp it will most likely drift to the left, asking for negative preload.) Sorry for the long winded answer.
[Re: rickseeman]
#1425307
04/26/13 12:59 PM
04/26/13 12:59 PM
MR_P_BODY
Cab... one of the factors some forget is that the rear end is trying to spin around the drive shaft... if you could hold the drive shaft with the rear end not in the car the rear end housing would spin in circles... its trying to do the same in the car.. the RR tire is trying to go up and the LR tire is trying to go down... thats why the LR tire tends to do more work and tends to drive the car to the right... so you need to help equalize the tire loads by adding the pre-load to the RR.. the amount of torque and the chassis flex dictate the pre load
