Re: Axle upgrades for 78' 440 Ramcharger [Re: Slant6pak] #1424602
04/29/13 12:12 AM
04/29/13 12:12 AM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
I owned a 77 W200 with factory 440, NP203 and optional D60 frontend. So yes. I quickly pulled off the hub drive plates and installed freewheeling hubs though along with a part time kit for the NP203.
Sheldon
Re: Axle upgrades for 78' 440 Ramcharger [Re: RUNCHARGER] #1424603
04/29/13 11:59 AM
04/29/13 11:59 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
Just find a D60 front from the 70s. I have 2
Re: Axle upgrades for 78' 440 Ramcharger [Re: 76dodgeboy] #1424604
04/29/13 01:00 PM
04/29/13 01:00 PM
Houston, Texas
Slant6pak Offline OP
Houston, Texas
I can't find anything locally...
Which is part of the problem. Seems everytime I see axles for sale they are up in the rust belt.
I have yet to find a junkyard in Houston that has any old Dodge trucks left. Its been over 2 years since I've seen a 72-80 in a yard.
2016 Challenger Scat Pack Shaker smile
1000 ci Brass Era Speedster project
Re: Axle upgrades for 78' 440 Ramcharger [Re: Slant6pak] #1424605
04/29/13 02:00 PM
04/29/13 02:00 PM
Graham, WA
P
Polarapete Offline
Polarapete  Offline
P
Graham, WA
You need to think outside the box...see my post above about the Chevrolet/GMC axles. My friend Bill was not a great fabricator, but he could bolt together parts and if I recall corectly the Chev/GMC driveline swap was nearly a bolt-in deal...the truck won't know what it is using for axles
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction
1998 Ram 2500 QuadCab, new daily driver.
2008 Honda Element
2014 Carry-On 7x14 Cargo Trailer
Re: Axle upgrades for 78' 440 Ramcharger [Re: Slant6pak] #1424606
04/29/13 07:05 PM
04/29/13 07:05 PM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
That's funny cuz' I can't find any rust free body parts locally. The ones I see online are in TEXAS!
Re: Axle upgrades for 78' 440 Ramcharger [Re: redraptor] #1424607
04/29/13 07:24 PM
04/29/13 07:24 PM
Houston, Texas
Houston, Texas
Nah none of that down here.
At least none that I can find in yards. 72-80 trucks down here are rusted out too, just not as bad.
My RC is swiss cheese below the bodyside molding. Probably could find a less rusty truck... but the patch panels are available and this truck has sentimental value to me.
Re: Axle upgrades for 78' 440 Ramcharger [Re: Slant6pak] #1424608
05/01/13 08:34 PM
05/01/13 08:34 PM
Lenox Iowa
MMiller Offline
MMiller  Offline
Lenox Iowa
Chevy axles are not bolt in....the spring pad width on the dana 60 front is at least an inch different. The two times I put 14 bolts in the rear of my Dodges, I had to cut the spring perches off and re-weld them. That is easy but the front end is not an easy deal. The Dodge springs are wider then the pads on a Chevy, and the passenger side is cast into the center section, so its not a cut/weld deal. Have cash in hand and be patient. Watch 1stgen.org classifieds, Pirate4x4 classifieds, and other cites like that for dana 60 fronts from Dodges.
Its not impossible, I just don't want the original poster to buy axles from a Chevy and they will swap in easily.
Michael
93 W250 CTD getrag, Bosch 185 injectors, AFE air filter. Trailer puller, daily driver,
90 W250 CTD 727 with smokin 5" stacks. Off road truck
75 Dodge W200 440 4spd 4x4 locked front and rear, twin disc clutch, E85. Pulling truck
Re: Axle upgrades for 78' 440 Ramcharger [Re: MMiller] #1424609
05/01/13 09:25 PM
05/01/13 09:25 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
You can find them cheap. I have 3 fronts. Paid $500 for from and rear $300 for another and $450 for the other. Alt of guys want $600+ for just the front. 70s D44hd/D60 from a 3/4 I wouldn't pay more than $300 for the pr unless Freshly gone through
Re: Axle upgrades for 78' 440 Ramcharger [Re: 76dodgeboy] #1424610
05/01/13 11:02 PM
05/01/13 11:02 PM
michigan woods
imfixinmopars426 Offline
michigan woods
use a dana 60 front open knuckle,with good spicer u-joints,and a gm 14 bolt rear.weld the snot out of the spiders to form a "Lincoln lock" and you will have a set of axles that will take a while to break...also use a 205 transfer. I ran a stout big block,and new TSL 44" swampers,and added hydro steering,and a ARB airlocker in the front..
note don't waste you time on any junk d44 fronts,OR any d60 rears. they snap like twigs! the 60 rears have very small axle shafts,and are not like our car units.if your not breaking these,you don't have any power..at all,lol.
Re: Axle upgrades for 78' 440 Ramcharger [Re: imfixinmopars426] #1424611
05/01/13 11:24 PM
05/01/13 11:24 PM
State of Confusion
hp383 Offline
Just a normal tag again
hp383  Offline
State of Confusion
Double check your brakes, IIRC the D44 and D44HD both use the same caliper, and pad.
Join the Penguin Liberation Front!!
Stop the Hippo Occupation!
Re: Axle upgrades for 78' 440 Ramcharger [Re: imfixinmopars426] #1424612
05/01/13 11:53 PM
05/01/13 11:53 PM
N
NITROUSN Online content
NITROUSN  Online Content
N
I ran 35 spline on my dana 60 with no issues. Ran 44 cut boggers or 14 paddle bigger diggers on 36 inch casings at about 1200 HP.
Re: Axle upgrades for 78' 440 Ramcharger [Re: MMiller] #1424613
05/09/13 06:50 AM
05/09/13 06:50 AM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
Michael
A chevy front end does bolt into a dodge. There is a bit of width difference, but it is close enough, especially with lift springs that alot of people just bolt them in and it works just fine.
Re: Axle upgrades for 78' 440 Ramcharger [Re: viperblue72] #1424614
05/12/13 03:18 PM
05/12/13 03:18 PM
Houston, Texas
Houston, Texas
Can somebody post a pic of the 75-79 Dodge D60 full time front axle?
I know these have drive flanges and are bolt in but I have no idea what this setup actually looks like....
Will the assembly have an part/casting numbers to identify it?
Dimensions?
I'm trying to get in contact with a local guy that is supposed to have a pile of Dana 60 fronts... I want to make darn sure I'm getting what I want before paying his price.
Re: Axle upgrades for 78' 440 Ramcharger [Re: Slant6pak] #1424615
05/12/13 03:48 PM
05/12/13 03:48 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I can get pics tonight or tomorrow morning. Got 2 sitting at the house. ones a DRW(duel rear wheel aka duelly) and other is SRW(single rear wheel) I have SRW hubs st swap the drw over. Has 4.88gears and will be in a 79 Clubcab Shortbox stepside with 6"suspension lift and 37" military tires and 440/4spd
