1985 D100 440 T56 magnum swap. #1424483
04/23/13 09:47 PM
04/23/13 09:47 PM
Clinton Twp. Michigan
coronet1966d Offline OP
I have about 90% of the parts, trans comes in tomorrow from summit T56 magnum 6 speed "road course" close ratio with a .63 OD gear.
pics tomorrow
Re: 1985 D100 440 T56 magnum swap. [Re: coronet1966d] #1424484
04/24/13 12:14 AM
04/24/13 12:14 AM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
Cool!
I hope ya list what parts ya use for the swap with pics!
84 D150 440/727
79 /6 swb D150
1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
Re: 1985 D100 440 T56 magnum swap. [Re: old_goat] #1424485
04/24/13 01:27 PM
04/24/13 01:27 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
Cool!
and good luck. looking forward to seeing it done
Re: 1985 D100 440 T56 magnum swap. [Re: 72d100] #1424486
04/25/13 11:37 PM
04/25/13 11:37 PM
trans came in today, didnt have a chance to work on it yet
Re: 1985 D100 440 T56 magnum swap. [Re: coronet1966d] #1424487
04/25/13 11:41 PM
04/25/13 11:41 PM
Re: 1985 D100 440 T56 magnum swap. [Re: coronet1966d] #1424488
04/26/13 12:33 AM
04/26/13 12:33 AM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
All I can do is
84 D150 440/727
79 /6 swb D150
Re: 1985 D100 440 T56 magnum swap. [Re: old_goat] #1424489
04/29/13 01:11 PM
04/29/13 01:11 PM
mocked up, gotta fab up a crossmember, shorten the driveshaft ect
Re: 1985 D100 440 T56 magnum swap. [Re: coronet1966d] #1424490
04/29/13 01:52 PM
04/29/13 01:52 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
Nice. have you cut a hole in your floor yet? are you happy with where that shifter location is going to be? I'm putting a viper spec T-56 into my Dakota, and I converted the front inspection cover to be a shift location using one of the kits on Ebay. it allows the shifter to move forward about 8" while still retaining the reverse lock-out feature. I believe the Magnum T-56 comes with this "conversion" already done, so all you have to do is buy the shifter mechanism itself.
Also, For reverse lock-out, I'm wiring mine into the brake light switch. When I step on the brakes, I'll be able to shift into reverse. I can't think of any situation where I'm going to be on the brakes during the 4-5 upshift, so I figured that was the easiest way to make the reverse lock-out "automatic" and seamless.
**Photobucket sucks**
Re: 1985 D100 440 T56 magnum swap. [Re: coronet1966d] #1424491
04/29/13 01:54 PM
04/29/13 01:54 PM
Houston, Tx
AlexP Offline
AlexP  Offline
Houston, Tx
Any trans tunnel clearance issues?
If not, I'm jealous.
My Build thread: Let the hemi swap begin!
1968 wanna be pro touring whatchamacallit with some fancy stuff and a new roof skin.
Re: 1985 D100 440 T56 magnum swap. [Re: AlexP] #1424492
04/29/13 07:30 PM
04/29/13 07:30 PM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
If it fits in a Dakota without clearance issues...it should fit in the ram!
and my motor is in the stock location with stock motor mounts.
Re: 1985 D100 440 T56 magnum swap. [Re: coronet1966d] #1424493
04/29/13 10:51 PM
04/29/13 10:51 PM
N
NITROUSN Offline
NITROUSN  Offline
N
I hope you dialed in that bell housing. I just dialed a friends blown 55 chev with that quick time bell and I had to get .014 offset dowels to get it in specs. That tranny wont shift right if you have clutch drag.
Re: 1985 D100 440 T56 magnum swap. [Re: NITROUSN] #1424494
04/30/13 12:32 AM
04/30/13 12:32 AM
everything is in the mock up stages right now, no tunnel modifications and it looks like ill be able to flip my shifter around to the "middle" position for a good shifter location.
im not looking forward to the bellhousing spec but it has to be done
Re: 1985 D100 440 T56 magnum swap. [Re: coronet1966d] #1424495
04/30/13 12:37 AM
04/30/13 12:37 AM
found a good RPM calc http://www.angelfire.com/fl/procrastination/rear.html
29" tire
3.55 gear
.63 OD gear
2200 RPM is 85 MPH
im going to drive this thing everyday its not raining
Re: 1985 D100 440 T56 magnum swap. [Re: coronet1966d] #1424496
05/17/13 12:30 AM
05/17/13 12:30 AM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
Any updates?
84 D150 440/727
79 /6 swb D150
Re: 1985 D100 440 T56 magnum swap. [Re: old_goat] #1424497
05/17/13 07:23 PM
05/17/13 07:23 PM
working on gettin the steel for the crossmsmber
Re: 1985 D100 440 T56 magnum swap. [Re: coronet1966d] #1424498
06/19/13 07:54 PM
06/19/13 07:54 PM
Marion Illinois
72d100 Offline
72d100  Offline
Marion Illinois
any updates?
Re: 1985 D100 440 T56 magnum swap. [Re: 72d100] #1424499
03/07/14 11:59 PM
03/07/14 11:59 PM
slow progress beats no progress
plating the rest of the frame next week
Re: 1985 D100 440 T56 magnum swap. [Re: coronet1966d] #1424500
03/09/14 11:14 PM
03/09/14 11:14 PM
Amarillo, Tx
old_goat Offline
Six Abuser
old_goat  Offline
Six Abuser
Amarillo, Tx
I know the feeling!
Looks like you put some thought into the crossmember.
84 D150 440/727
79 /6 swb D150
Re: 1985 D100 440 T56 magnum swap. [Re: coronet1966d] #1424501
03/10/14 01:01 AM
03/10/14 01:01 AM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
I have the same exact trans and just had to pull it and flip my ring gear on the flywheel. It was pain to put back at first I just had the wrong angle. You are gonna love it and so good to know it is easy to service or swap and has a sixth gear
You may have the older output shaft seal. Call Tremec and give them the serial number on the passenger side tag and they will send an updated seal for free
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: 1985 D100 440 T56 magnum swap. [Re: RylisPro] #1424502
03/12/14 05:17 PM
03/12/14 05:17 PM
what do you mean about the flywheel?
