May have crossed a plug wire. How do I fix #142144
10/27/08 10:41 AM
10/27/08 10:41 AM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
I'm gonna get laughed at on this one, but how do I know if I crossed a wire? I don't know the firing order, but also need to know how do I match the wires from the distributor to the plugs? Engine is a 360.
Re: May have crossed a plug wire. How do I fix [Re: 68Bullit] #142145
10/27/08 10:44 AM
10/27/08 10:44 AM
3
340dart4spd Offline
Parts Problem
340dart4spd  Offline
Parts Problem
3
I'm gonna get laughed at on this one, but how do I know if I crossed a wire? How do I check it as far as firing order and the right way the wires go from the distributor to the plugs?
small block or big block?
Small Chrysler: Clockwise 1-8-4-3-6-5-7-2
• Big Chrysler and Hemi: Counter-clockwise 1-8-4-3-6-5-7-2
Re: May have crossed a plug wire. How do I fix [Re: 68Bullit] #142146
10/27/08 10:47 AM
10/27/08 10:47 AM
Upper Midwest
MoparforLife Offline
Upper Midwest
Firing order 18436572 clockwise around the cap SB abd counter clockwise big block.
Small block diagram. But number one can be anyplace as long as the firing order is followed and number one is located with the number one piston at TDC and in the firing position. 5 & 7 are the easiest to cross as they are next to each other in the capand also in teh firing order..
Re: May have crossed a plug wire. How do I fix [Re: MoparforLife] #142147
10/27/08 11:00 AM
10/27/08 11:00 AM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
Thanks Gentlemen. Firing order looks right. Looking at my distributor, and the #1 on the Dist. is marked, however it is sitting where the two should be (according to your diagram). Is that because the timing has been advanced maybe?
Re: May have crossed a plug wire. How do I fix [Re: MoparforLife] #142148
10/27/08 11:11 AM
10/27/08 11:11 AM
Western NC
68Bullit Offline OP
68Bullit  Offline OP
Western NC
I should read more closely. Thanks for your help
Re: May have crossed a plug wire. How do I fix [Re: 68Bullit] #142149
10/27/08 11:27 AM
10/27/08 11:27 AM
US of A
A38s! Offline
A38s!  Offline
US of A
Was trying to be the Big Man at 14, and give my cousin's Fury a tuneup. Grandpa ended up towing it home to fix. All was good, except the rotation .
WANTED: Your 71-78 Late B-body sedan parts! Police or Civilian.
Re: May have crossed a plug wire. How do I fix [Re: A38s!] #142150
10/27/08 02:55 PM
10/27/08 02:55 PM
Omaha, Nebraska
Scott Carl Offline
Scott Carl  Offline
Omaha, Nebraska
Not sure about aftermarket, but if its a stock intake, firing order is embossed on the manifold
Re: May have crossed a plug wire. How do I fix [Re: Scott Carl] #142151
10/27/08 03:03 PM
10/27/08 03:03 PM
US of A
A38s! Offline
A38s!  Offline
US of A
I think that came about in the mid 70's, after my bumble.
Family never lets ya off the hook once that happens... I'll get a call about it when we move the clocks back next Sun.
