Re: Transmission Slipping 2nd Gear
[Re: rtse70]
#142128
12/19/08 05:15 PM
12/19/08 05:15 PM
Posts: 25,786 Rio Linda, CA
John_Kunkel
Rio Linda, CA
If the 2000 Grand Cherokee in you signature line is the subject, it could have one of three different transmissions depending on the engine. Two of them have an external front band adjustment that could solve the problem. If it has a 4.0L or 5.2L engine the 42RE and 44RE adjustment shown on the link below can be performed. http://dodgeram.org/tech/transmission/automatic/AT_band_adj.htmIf it's a 4.7L there is no adjustment.
[Re: John_Kunkel]
#142129
12/19/08 06:01 PM
12/19/08 06:01 PM
Posts: 920 Indy
rtse70
Indy
It's a 4.0 (I don't believe either of the others have external bands but not sure). I really think the kickdown band is the issue, I'll have to check with some other places this place is obviously trying to hose me.
Thanks to you both!!
