Anyone use an aftermarket AutoMeter Fuel Gauge? 0-90ohm
#1420341
04/15/13 04:28 PM
04/15/13 04:28 PM
Posts: 1,011 Central US
grancuda
Central US
Looking at getting a 0-90ohm fuel gauge for my '69 RR. Anyone else use this 0-90 range and will it work. My factory gauge won't work the gauge is messed up. I have a new factory style sending unit.
1967 Barracuda Formula S 383 1967 Chevy C10 Short Stepper 1980 Macho Power Wagon LWB 318 2021 Toyota Supra
Re: Anyone use an aftermarket AutoMeter Fuel Gauge? 0-90ohm
[Re: 70Duster440]
#1420343
04/15/13 06:50 PM
04/15/13 06:50 PM
grancuda
Central US
You should be using a 10-70 ohm gauge with a factory sender.
I am finding Autometer showing 73-10ohm is for Chrysler, anyone buy one like this for a factory Chrysler sending unit?
[Re: fourgearsavoy]
#1420346
04/15/13 09:33 PM
04/15/13 09:33 PM
Posts: 1,069 Washington State
70Duster440
Washington State
Preston that is one VERY nice street machine Gus
Thanks, Gus!
Also grancuda, just an "FYI", this is what Auto Meter told me with regards to the use of reproduction "factory" senders - which I'm guessing is what you installed:
The gauges are calibrated to match a factory sender, which is very non-linear. 10 ohms = Full, 25 ohms = 1/2, 50 ohms = Empty, and 73 ohms = below Empty. With this said, most after market, or reproduction senders are built linear which means that E & F will be correct, but everything in between will be skewed.
