Which wire goes to washer pump switch 69 GTX #1419855
04/14/13 03:20 PM
04/14/13 03:20 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Dash had to come apart to repair some wires in main harness. There are 4 separate brown wires; one of them I know goes to the wiper motor switch. Two go to the washer pump switch. The washer switch is a two post switch. Which wire goes on which post of the washer switch? Does it make a difference? If they go on the wrong post will I have another melt down?
Re: Which wire goes to washer pump switch 69 GTX [Re: frank] #1419856
04/14/13 03:29 PM
04/14/13 03:29 PM
N
NITROUSN Offline
NITROUSN  Offline
N
They can plug on either way.
Re: Which wire goes to washer pump switch 69 GTX [Re: NITROUSN] #1419857
04/14/13 03:31 PM
04/14/13 03:31 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
Where does the fourth wire go? To the wiper motor switch?
Re: Which wire goes to washer pump switch 69 GTX [Re: frank] #1419858
04/14/13 03:36 PM
04/14/13 03:36 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Do you have 2 or 3 speed wipers? If 2 speed one wire is not used.
Re: Which wire goes to washer pump switch 69 GTX [Re: NITROUSN] #1419859
04/14/13 03:43 PM
04/14/13 03:43 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
I don't know. The wiper motor switch has four positions and 7 terminals on the back so I'm going to assume its a three speed: off, slow med, high?
Re: Which wire goes to washer pump switch 69 GTX [Re: frank] #1419860
04/14/13 03:57 PM
04/14/13 03:57 PM
N
NITROUSN Offline
NITROUSN  Offline
N
On the washer switch one wire goes to the pump and other is just a short jumper from the washer switch to the corner of the wiper switch where it gets its power from. So that's 3 of your 4. The last is on the switch to to motor.
Re: Which wire goes to washer pump switch 69 GTX [Re: NITROUSN] #1419861
04/14/13 04:16 PM
04/14/13 04:16 PM
tucson az
frank Offline OP
frank  Offline OP
tucson az
So for the three wires (2 pump switch, 1 to wiper motor switch) It makes no difference which wire goes where as long as all three wires are hooked up.
