Re: Spray Welding
[Re: ScottSmith_Harms]
#1419505
04/14/13 09:49 AM
04/14/13 09:49 AM
Posts: 22 Indiana
RagtopChallenger
Indiana
Can anyone reccomend someone who can do spray welding on cast iron?
As a Machinist in a roll shop we tried spray welding the worn bearing fits.(Undercut,spray weld, then grind to finish size) After the next 30 day inspection we discovered that it was chipping and breaking away. We went back to pre-heating, stick welding with Ni-Rod, and very SLOW cooling. Bearing in mind that this is just my experience with it and maybe others have better stories to tell. One more thing, no more than 0.030" thick if you try it.
Good Luck!
Rusty
Re: Spray Welding
#1419507
04/14/13 11:08 AM
04/14/13 11:08 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
I have an exhaust manifold that was laying in the mud and rusted thin along an area, I'd like to try and save it by building up the thin area.
*Ralph doesn't know anyone doing it
I bet it's a 440 driver's side A-body manifold...
