trans/xfer ID plez #1419423
04/14/13 12:34 AM
04/14/13 12:34 AM
scratchnfotraction Offline OP
this is the 5 speed for my son piglets XJ 4x4 conversion.
I need some info and have some ?s with it.
does the xfer just unbolt from trans housing? any seals or gaskets needed in this area?
what 5 speed trans is this known as?
what xfer is this known as?
whats the deal on replacing the throw out bearing/hydro lines?
all ez or PITA to work with?
I would like to install the 5 speed,then bolt up the xfer. but if it is a hassle to remove the xfer, I guess we can lift it as a whole unit.
here is the new look piglet come home with. I dont get the no door thing myself.
I have done plenty of mudding here in FL in my day. doors are sure nice to keep mud off, skeeters out. nice to have some refuge from the wild now and then.
but it is his thing. I just got him hooked on the mud and spinning the tires
he just got the winch hooked up to pull his buddys 2x jeep out when playing.
Re: trans/exfer ID plez [Re: scratchnfotraction] #1419424
04/14/13 12:34 AM
04/14/13 12:34 AM
Re: trans/exfer ID plez [Re: scratchnfotraction] #1419425
04/14/13 12:37 AM
04/14/13 12:37 AM
his buddy cow patty had to have the same look.
spray bomb black and no door club.
Re: trans/exfer ID plez [Re: scratchnfotraction] #1419426
04/14/13 12:38 AM
04/14/13 12:38 AM
now for the trans and exfer pics.
Re: trans/exfer ID plez [Re: scratchnfotraction] #1419427
04/14/13 12:39 AM
04/14/13 12:39 AM
5 speed
Re: trans/exfer ID plez [Re: scratchnfotraction] #1419428
04/14/13 12:40 AM
04/14/13 12:40 AM
hydro TOB
Re: trans/exfer ID plez [Re: scratchnfotraction] #1419429
04/14/13 08:37 AM
04/14/13 08:37 AM
Greenville, PA
redraptor Offline
redraptor  Offline
Greenville, PA
Looks like cow patty's tires would get stuck on wet grass.
Re: trans/exfer ID plez [Re: redraptor] #1419430
04/14/13 09:15 AM
04/14/13 09:15 AM
it pretty much does.
Re: trans/exfer ID plez [Re: scratchnfotraction] #1419431
04/14/13 09:34 AM
04/14/13 09:34 AM
Sunny South Florida
Golden-Arm Offline
Golden-Arm  Offline
Sunny South Florida
i just did a slave cylinder pressure plate setup for my next door neighbor. pretty straight forward, just disconnect the line(s) at the slave cylinder, and remove. it can be done with a screwdriver and a lot of patience, but the tool to do it, makes it much easier. if you do a new slave setup, a good one will include the tool to disconnect the lines.
dont remember the mounting of the xfer to the trans, but some have a gasket, some dont. if yours does, it needs to be sealed on both sides, with some permatex when installing. if one isnt there (presuming it's untouched before you open it) then it wont need a gasket to go back together.
Re: trans/xfer ID plez [Re: scratchnfotraction] #1419432
04/14/13 10:41 AM
04/14/13 10:41 AM
Maine
jerseybud Offline
jerseybud  Offline
Maine
It looks like a nv3500 and a 231 tc. What year is the jeep?
ax-15 and 3550 also possibilities
Re: trans/xfer ID plez [Re: jerseybud] #1419433
04/14/13 10:55 AM
04/14/13 10:55 AM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
They had a junk pugoet trans too.
