Epoxying Mechanical advance slots- Updated
#141888
10/26/08 08:11 PM
10/26/08 08:11 PM
I changed a spring in my distributor (stock electronic ign SB mopar- vintage unknown) and checked my timing.
When I adjust it to get 32 degrees total advance, I have something stupid like 0 or 2 degrees advance. will not work for me.
So I can buy a new distributor but just for jollys, I want to shorten up the slots in the centrifical advance. I heard I could JB weld it.
About how much do you go to get 18 degrees initial at 1000 rpm and below and a total of 32 dgrees. I know its a rough estimate. just looking for a starting place.
Re: Epoxying Mechanical advance slots
#141889
10/26/08 08:19 PM
10/26/08 08:19 PM
Posts: 21,822 Kirkland, Washington
Pacnorthcuda
So you have a bout 30 degrees total mechanical and you want 14....roughly half. Just pull the Dist and examine the amount of travel that the 'pins' travel in slots as you operate the advance by hand. Then just epoxy up about 1/2 that. Keep in mind you may want to use a round rat-tail file on the epoxy after cure to fine tune the amount, get it even from side to side, and create a nice arc for the pin to stop against
[Re: Pacnorthcuda]
#141890
10/26/08 08:37 PM
10/26/08 08:37 PM
btw, do some stock distributors actually come with this much initial? I could have bad numbers (things were jumping around a lot) but thats what it looked like
[Re: mrpatel]
#141892
10/26/08 09:43 PM
10/26/08 09:43 PM
RapidRobert
I had some Jb weld come loose on one of mine so I started welding them. A good timing chain and adding a collar on the end of my dist shaft where it fits into the intermediate shaft made my timing marks rock steady
#141893
10/26/08 10:01 PM
10/26/08 10:01 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
Yes , for some odd reason mopar has a mile of mechanical advance built into most all distributors .
[Re: cogen80]
#141899
10/27/08 01:01 PM
10/27/08 01:01 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
here ya go i found the magazine,
dist. degrees X 2 + initial= total
dist. degrees / slot size 6.............. .340 7............... .355 8............... .375 9............... .390 10.............. .405 11.5 ........... .420 12.............. .435 13.............. .445 14.............. .460 15.............. .475 16.............. .490 17.............. .505 18.............. .520
Right click, save as... Thank You!!!
[Re: cogen80]
#141900
10/27/08 01:23 PM
10/27/08 01:23 PM
BAM! YOU DA MAN!
I was searching EVERYWHERE for that chart but only found bits and pieces for 1 or 2 slot lengths (and even those were suspect.
I ended up doing some measureing this morning on my pieces and came up with what I imagined would be the correct slot length for roughly 14 degrees of advance (thats 18 initial + 14 mech = 32 total) and figured the slot should be about .340"
your chart shows about .355" for 14 degrees at the crank so I wasnt too far off. I'll start with .340 and see what I get.
Thanks!
[Re: Stanton]
#141903
10/27/08 01:43 PM
10/27/08 01:43 PM
Posts: 5,337 the house on the left.
cogen80
What motor is this ... isn't 38 degrees the ideal amount of total advance for most Mopars ???
looks like some kind of small block. i run 35* +/- total in my small blocks and 38* +/- in my big blocks.
#141904
10/27/08 01:47 PM
10/27/08 01:47 PM
Posts: 1,396 Mass
dgc333
Mass
If you are going to purchase a new distributor get a MP unit. The slots are adjustable on them so you can set it to what ever you want.
[Re: cogen80]
#141905
10/27/08 03:54 PM
10/27/08 03:54 PM
Posts: 3,010 Sac, CA
mopowers
Sac, CA
Is this for a BB or a SB? Or both?
Thanks for posting that chart by the way. That'll be nice to have.
[Re: cogen80]
#141907
10/27/08 05:37 PM
10/27/08 05:37 PM
i am running a 416 sb. typically, I do run my 340's/360's at 34-36 degrees total. But Ive read in several places now that strokers like their timing down around 30-32. So I want to give it a shot.
