'71 Charger Instrument Voltage Limiter Questions w/pic
#1418765
04/12/13 01:01 PM
04/12/13 01:01 PM
Posts: 70 ND
Birdlover
ND
I removed the voltage limiter (see photo) since my fuel and temp gauges are not working on this recently acquired car. When I put 12V to the center terminal and ground the right terminal, I get a flucuating 2v to 5v output on the left terminal. The output reading changes about 2x every second--I believe I should be getting a constant 5v output reading. My questions are: 1. Is my voltage limiter bad and if so, where is best place for a new one? 2. Mounted near the voltage limiter on the instrument panel is condenser with one short wire lead and spade terminal on the end. I can see no place to connect this wire. What is the purpose of this condenser and to what does it connect? Thanks!!
1969 Road Runner, B7 Blue, 383, Auto
Re: '71 Charger Instrument Voltage Limiter Questions w/pic
[Re: Birdlover]
#1418766
04/12/13 08:16 PM
04/12/13 08:16 PM
RapidRobert
(1)a No b RT enterprises (2)a absorbs voltage spikes b not sure but I'd imagine i'td be like a points condensor, the case would be grounded & the lead to one of the hot terminals. I'd search elsewhere (but closeby) for the open on your gas/temp gauges
[Re: Andrewh]
#1418769
04/12/13 10:56 PM
04/12/13 10:56 PM
Posts: 18,426 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
that condencer is a capacitor to even out the blinking.
Not true. Its there to absorb noise and it really is a noise suppressor. Cars without radios did not always have them. Old AM radios were horrible for picking up electronic noise and sending them out the speakers. Back in the day when we would do an oem radio install there was a kit with several suppressors.
[Re: 451Mopar]
#1418771
04/15/13 12:38 AM
04/15/13 12:38 AM
NITROUSN
The capacitor dampens out the pulses to ideally get an average voltage of 5 volts.
No it does not. It is a noise suppressor only. Cars without radios did not have them. Read a fsm and you will learn.
