Charger REwire gone HAYwire...It RUNS now!
#1418657
04/12/13 04:02 AM
04/12/13 04:02 AM
Posts: 18,493 Granite Bay CA
Kern Dog
Striving for excellence
Granite Bay CA
I had a friend help me with a rewire job on my 70 Charger. It isn't working out so good though. Before I get too far, a bit of a backstory... Bob has a 71 Road Runner. 5 years ago he had an electrical snafu that almost led to a meltdown. After getting his car back home, he went through the wiring and replaced everything. After the changes, his car has performed like it should. 2 months ago I had trouble getting my Charger to start when I tried to leave a car show. I got the car started and drove it home, but I wasn't confident to drive the car much. Bob saw this as a great opportunity to help me rewire the car. Made sense to me. The wiring was almost entirely original and surely could benefit from an update. Bob had the idea to use relays in a box to power up the ignition and headlights. The BATT + on the starter relay fed the power to those relays. We ran ONE 10 ga wire from the relays to the + side of the coil. Bob thought that the ballast resistor was UNnecessary for an electronic ignition, so the coil had full power. Things didn't make sense to me but I trusted what he was doing. The coil + terminal served as a junction to also connect the blue wire to both the Voltage Regulator and the blue ALT field terminal. The ECM plug was wired as per the MP ignition kit instructions MINUS the ballast. Of COURSE it wouldn't start. We tried several times. ZERO spark coming from the coil wire. I'd heard members here say to use the ballast and told Bob that we should, so he switched a few things around and we integrated one. Still no spark. The coil+ gets 11 volts, the coil- gets around 5. How can power get TO the coil but get nothing out? The brown wire and blue wire are the run and crank. When the key is in the RUN position, I get power to BOTH wires. Is this right? It would seem to me that the RUN wire should be on, but the CRANK should only energize when the key is twisted to crank the starter.... Here is another really odd symptom: sometimes while cranking and getting no spark, when turning the key back to lock, it tries to fire. It did this before we disturbed anything. It did this with NO ballast. It does it with different ballasts. It doesn't do it every time, but it has done it with many different combinations. Finally, yesterday while messing around with no clear idea of what I was doing, I spritzed ether down the carb and twisted the key. It fired up and ran like normal! I was so confused by this. I started it up at least 10 times after that with nothing more than a twist of the key and a light tap on the throttle. This morning it started fine. I tried again moments later and it failed to fire. I appreciate any and all positive suggestions anyone can offer. I am grateful to Bob for trying to help out, but I think we bit off more than we can both chew on this one.
Re: Charger REwire gone HAYwire....HELP !!!
[Re: Kern Dog]
#1418660
04/12/13 11:04 AM
04/12/13 11:04 AM
RapidRobert
Seperate & check/clean the bulkhead terminals (wire brush for the male ones/spare male terminal for the female ones then spray with contact cleaner & blow dry em). Take off the yellow "ign" wire from the starter solenoid to avoid running the batt down (& no need for the noise distraction). It started so there's a loose/poor connection somewhere (check em all) & it's very likely wired right if power goes thru the ballast in ign1(run). You have fire at the coil primary & the ECU needs to open the coil neg pri circuit to fire the coil and the dist pickup triggers the ECU to do that. In "crank" (ign2) the brown wire circuit; the "point" of the ECU pentastar connector and the coil positive primary need fire (assuming 4 pin ECU/2 terminal ballast). In "run" same thing; the (ign1) blue wire circuit the "point" of the ECU pentasstar and the coil positive primary terminal need fire & as you know it goes to/thru the ballast first before it gets to the coil positive primary. Check ECU ground. Your VOM is your friend along with a helper (Bob!) to hold the key to start for your ign2 "crank" circuit tests. EDIT Check the reluctor gap & start unplugging/replugging connectors/checking tightness/clean connections etc & work your way toward the coil/ECU. Holler how it goes
[Re: Mr.Yuck]
#1418662
04/12/13 02:27 PM
04/12/13 02:27 PM
Kern Dog
Granite Bay CA
sounds like you Mickey Moused your system. Time to un-monkey it. Buy the factory harness and replace it.
THIS
is the nicest way to tell a guy that he screwed up! I agree totally. Bob really gave it the good fight. He had the idea of rerouting wires for a cleaner look. He shortened paths and eliminated "redundant" wiring. I was happy with the factory setup and wanted to buy a reproduction harness from the start. Bob said.."These harnesses were barely adequate when they were new." Once again, I agree with Mr Yuck: The existing harness lasted this long didn't it? I feel beat down. Bob knows more about electrical stuff so out of respect, I often deferred to his ideas....until this morning. I ordered a new harness from Evans wiring from Pennsylvania. Engine harness and headlight harness. It will take a week to get here so I'll continue to test things to see where it all went wrong. I have a few fire extinguishers nearby just in case!
[Re: Kern Dog]
#1418664
04/12/13 02:40 PM
04/12/13 02:40 PM
Posts: 24,562 Brookeville, Md
Mr.Yuck
Brookeville, Md
THIS
still clean up the bulkhead. Go to radio shack and get the contact spray cleaner, that stiff works good. Do both sides of the bulk head and re-sand all the grounds. Been there done that.
[Re: Kern Dog]
#1418666
04/12/13 03:29 PM
04/12/13 03:29 PM
Posts: 1,037 Texas, Dallas
G_T
Texas, Dallas
"Here is another really odd symptom: sometimes while cranking and getting no spark, when turning the key back to lock, it tries to fire. It did this before we disturbed anything" Hard to tell with all the other changes/etc. - but "sometimes" this is a symptom of a boogered/failing ignition switch. I'd check that carefully and perhaps replace it - could be worn out. If it was me, I'd disconnect the battery cables completely until you replace with the new wires - it would suck to have a fire when your not there to see it and use your fire extinguisher...
1970 Charger - V10, 6spd, Alterkation, Street Lynx 4 Link, Moser Dana 60, Wilwood 14" disks, Forgeline 18" Wheels (Rear:335's), ISIS Multiplexing Wiring http://www.v10mopar.com
2012 Charger SRT8
[Re: G_T]
#1418667
04/12/13 04:25 PM
04/12/13 04:25 PM
dogdays
Funny thing, I diagnose your problems as all starting from a bad ignition switch. When you turn the key to start, the ignition is fed around the ballast resistor. If the car cranks and doesn't fire, but tries to when the swithch is turned back to "run", that's your issue.
Using a stock ignition module, a few things have to be right: 1. Distributor should be grounded. 2. Ignition box must be grounded. 3. Ignition coil must be grounded.
During running, the positive terminal of the coil gets 12 volts through the ballast resistor which usually knocks it down to 8-9 volts. The negative terminal of the coil is grounded through the ignition box. Thus current charges the coil. When the points open or the magnetic pickup sends a signal to the box, the flow of electricity through the coil is interrupted and the magnetic field breaks down, causing current to flow out of the coil secondary winding, to the distributor and finally to spark plugs. To complete this circuit the coil must be grounded. If you're seeing voltage at the coil negative terminal, the ignition box isn't grounded well enough.
It's easy for others to tell you when you or a friend has screwed up, but it seems to me that you guys were almost there, just a few mistaken ideas.
When you install your new "factory" wiring, be sure to check the bulkhead connector because it's a possibility that the connector from your ignition switch "start" wire is damaged, which would explain why the differrent ignition switch didn't help.
I hope to never use a ballast resistor again. Every build I do uses a solid state CDI, I am using a MSA-6 on my '64Dog and the Accel 300+ on two others. There, instead of 8 volts or whatever charging the coil, I have 450 volts or so charging the coil. I don't think the chances of ignition box failure are worse for either the stock box or a reputable aftermarket box, I've never had one go bad. There is a question about the orange box on the '64Dog but that's inactive at present.
Feeding headlights and other big amp loads with relays is a good idea, too
R.
[Re: Kern Dog]
#1418669
04/12/13 08:58 PM
04/12/13 08:58 PM
Posts: 15,487 Florida
scratchnfotraction
that pertronix points conversion with flamethrower coil is sounding better and better..NO? this is the very reason I ditch the stock ecu elect anything crap on my junk. been right where you are to many times to do it any other way now. they get the pertronix fix..and on a points car with points conversion they are a huge improvment of stock points. I will not I know the beatdown feeling all to well working on SOMETHING THAT IS NOT BROKE TILL IT IS BROKE!...
[Re: scratchnfotraction]
#1418670
04/13/13 01:00 AM
04/13/13 01:00 AM
Kern Dog
Granite Bay CA
Okay, here goes: I went back to the car and continued to poke around. I pulled the 3 engine side bulkhead plugs to make sure all of the spades were pulled through enough. They all were. I pulled the bulkhead back into the underdash area to make sure that all the wires were pressed deep enough into the master plug. They were. Every connection in the harness was checked for correct fit. THEN I took the tester to it all again. I checked my findings against a 72 Duster with electronic ignition, a 75 Power Wagon, a 78 Trail Duster and a 67 Dart. All of them showed between 4.0 to 7.0 to coil+ at run. The coil- was always near 1.0 in those 3 cars and the Charger. The numbers made me think that the coil and ECU were getting power in as they should. I was pissed, so I walked away. Moments later as I was kicking back, it occured to me. The only reason that a properly functioning coil should get power IN but not OUT is because it isn't receiving a proper signal from the distributor! I plugged in a spare factory electronic distributor and the car instantly fired up! The reluctor gap was set correctly. The wires were in great condition. I think that the pickup simply crapped out. I swapped in a reluctor and pickup from another spare and was just about to put it in when a friend came over. After he left, it was dinner time. I'll finish tomorrow. Bob's wiring actually worked. The cars other wiring was fine too. The coil, ECU, ballast resistor and Voltage Regulator all were fine. The distributor was part of a Mopar Performance conversion kit I bought in 2001. I've had the No-Spark problem on occasion with this distributor in the past. I'd just junk it but it was curved to a maximum of 14 total degrees. I run 17 initial and 31 degrees total. Any less than 17 at idle and it runs choppy and lazy. Any more than 31 and it rattles like marbles in a soda can. Thanks to all!
