alternator over charge #1418303
04/11/13 05:08 PM
04/11/13 05:08 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
This is driving me crazy. My charging system is running at 15+ volts. It's a two field alt and I have gone through 4 VRs and still no difference. I have a ground wire for the VR as well as a new plug. The green wire to the VR from the alt has continuity as well as power with the key on.I have battery voltage at the main alt post plus batt voltage to the other (red)field terminal. I am using a volt meter and it pulsates as do the lights. What am I doing wrong that makes the alt put out such a high voltage?
Re: alternator over charge [Re: stumpy] #1418304
04/11/13 05:23 PM
04/11/13 05:23 PM
Indiana
GrnMagic77 Offline
Peter Parker
GrnMagic77  Offline
Peter Parker
Indiana
Maybe temporarily swap out the battery with a known good one just to see if it makes a difference then go from there.
1978 Round Up-1977 Warlock-1977 Powerwagon Adven.- 1976 Blue "Macho"-1974 Charger-1968 Fury III -1966 Newport *
Re: alternator over charge 1983 D150 [Re: GrnMagic77] #1418305
04/11/13 05:25 PM
04/11/13 05:25 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
Should I have power from the green wire with the key on and the engine not running?
Re: alternator over charge 1983 D150 [Re: stumpy] #1418306
04/11/13 06:03 PM
04/11/13 06:03 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
yes... on mech reg, positive pole... on elect regs negative pole
Re: alternator over charge 1983 D150 [Re: stumpy] #1418307
04/11/13 06:05 PM
04/11/13 06:05 PM
You'd have switched 12V to the blue wire terminal at the alt field then it'd go in/thru/out the internal field to the outside green wire field terminal so yes. take off both field wire female connectors & see if there's continuity between the 1 green wire male terminal on the brush assy to ground (should not be) & check the brush & it's holder for continuity to ground somewhere (should be no continuity). Something is grounding & making the field circuit full field on the green wire grounding side just like it would if you deliberately full fielded the green wire. Holler how it goes Stump!
Re: alternator over charge 1983 D150 [Re: RapidRobert] #1418308
04/11/13 06:23 PM
04/11/13 06:23 PM
Valencia, España
NachoRT74 Offline
NachoRT74  Offline
Valencia, España
I should say, the green wire gets negative pole AT BRUSH END disconected, but checking from regulator plug disconected, green wire will test for positive pole, due the power coming in from to the blue wire alt brush and coming out from the other bush once goes by the rotor
Re: alternator over charge 1983 D150 [Re: NachoRT74] #1418309
04/11/13 06:53 PM
04/11/13 06:53 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
Look for a bad connection somewhere in one of your heavy load lines. Like the one that goes up the steering column, at the bulkhead, etc. I had a burned connection on my column. Drove me and a few garages nuts for about 2 years. One day I noticed a black streak in the heavy wire in the plastic coupler. I bypassed the coupler and that cured the overcharging.
Re: alternator over charge 1983 D150 [Re: NachoRT74] #1418310
04/11/13 06:58 PM
04/11/13 06:58 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
No continuity from either brush to ground. I have battery voltage to a red wire at the brush, maybe the blue wire you mentioned, and at the main terminal. At the regulator I have battery voltage at the green wire from the alt and nothing on the blue wire with the key on engine not running. With the key off I only have battery voltage to the main alt wire.
Re: alternator over charge 1983 D150 [Re: stumpy] #1418311
04/11/13 07:20 PM
04/11/13 07:20 PM
Andrewh Online content
Andrewh  Online Content
not just voltage and continuity.
how much voltage.
if it is low you will over charge.
there are several places you could be loosing voltage in the sensing line as well.
power goes in, through the switch then back out again, and the connector.
any of these things could drop the voltage as well causing the vr to over charge.
Re: alternator over charge 1983 D150 [Re: stumpy] #1418312
04/11/13 08:42 PM
04/11/13 08:42 PM
Stump does this have a std 70's setup with green/blue field wires? Blue to an alt field. Blue to reg top terminal. green from reg side terminal to the other alt field. Where is the "red" wire in all this? You said "nothing on the blue wire" etc; you'd need switched 12V at the blue wire at the reg top terminal in the triangle with the key on (eng on or off) & the blue field wire at the alt would be hot with key on also (switched 12V)
Re: alternator over charge 1983 D150 [Re: RapidRobert] #1418313
04/11/13 09:29 PM
04/11/13 09:29 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
Thetwo feld wires are green and red. The VR wires are red and green with green to the side and red at the top.I get no power to the top VR terminal. Looks like I am having some ignition switch issues but I will replace it tomorrow.
Re: alternator over charge 1983 D150 [Re: stumpy] #1418314
04/11/13 09:47 PM
04/11/13 09:47 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
I found a wiring diagram and it looks like the red at the alt and the red at the Vr are the same circuit coming from the ignition switch. The guy I got the truck from did some rewiring and It looks like I get to redo it.
Re: alternator over charge 1983 D150 [Re: stumpy] #1418315
04/11/13 09:56 PM
04/11/13 09:56 PM
You might jump 12V to the "red" male alt terminal & 12V to the "top" male nub terminal on the reg & see if it straightens out
Re: alternator over charge 1983 D150 [Re: RapidRobert] #1418316
04/11/13 10:02 PM
04/11/13 10:02 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
Right after I finish with the ignition swap. Hopefully I will be able to figure out what was done to the wiring then.
Re: alternator over charge 1983 D150 [Re: stumpy] #1418317
04/12/13 12:50 AM
04/12/13 12:50 AM
hooziewhatsit Offline
Another quick test ( )
Put your voltmeter leads on the battery+, and on the red wire* at the alternator. This voltage should be close to 0v. My bet is that it's ~.75v, or exactly the amount your voltage is above what it should be.
(battery should be 14.4v. If you're seeing 15.2v, you would see 0.6v with this test. This is the culmination of all the voltage drops from the battery to the red wire at the alt)
*For stock non-hacked systems, this is the blue wire.
Re: alternator over charge 1983 D150 [Re: hooziewhatsit] #1418318
04/12/13 12:59 AM
04/12/13 12:59 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Stumpy, have you checked for full voltage to red wire at the regulator? That is what the regulator uses as a reference... If it is low the regulator will force the alternator to over charge.. As you know a marginal ground to the regulator will do the same thing... Good Luck..
Re: alternator over charge 1983 D150 [Re: hooziewhatsit] #1418319
04/12/13 01:11 AM
04/12/13 01:11 AM
If the batt is showing 14.4V & alt is showing 15.2V should the VOM read 0.8V
Re: alternator over charge 1983 D150 [Re: RapidRobert] #1418320
04/12/13 01:54 AM
04/12/13 01:54 AM
Derp. Math is hard
Re: alternator over charge 1983 D150 [Re: hooziewhatsit] #1418321
04/12/13 01:57 AM
04/12/13 01:57 AM
I wanna do your test & just wanted to have it right
Re: alternator over charge 1983 D150 [Re: RapidRobert] #1418322
04/12/13 02:57 PM
04/12/13 02:57 PM
Grand Prairie,Texas
stumpy Offline OP
stumpy  Offline OP
Grand Prairie,Texas
Ok voltage drop test shows .59. Voltage at the VR red (top) terminal is 14.75 and gren wire 0 with motor off key on . Running the red shows 14.75 and the green keeps cycling from 8-10.5. Amp gauge shows discharge with the lights on but never shows a charge. Volt meter on dash shows 15+ and flickers and the VOM shows 15.8 at the battery. I also noticed when you start the engine the volt meter will sit at battery voltage for a second and then climb to 15+. Just to be clear the power feed doesn't go through the amp gauge like the older trucks. Ignition switch is new and bulkhead connector shows no corrosion. Could a bad diode or something in the alternator be causing this?
