Head Gaskets Block Coolant Passages
#1418034
04/11/13 01:54 AM
04/11/13 01:54 AM
Posts: 5,161 CT
GTX MATT
CT
I bought a set of Mr Gasket steel shim gaskets for my 440 with Stealth heads. When checking the fit around the combustion chambers I noticed a severe blockage of some of the coolant passages. I'm thinking Whiskey Tango Foxtrot, stupid aftermarket junk. So I dragged a 906 out from under the bench, same deal. Stupid Mr Gasket [Edited by Moparts - Family Friendly Site - Keep it clean] So I got out one of the fel pro 8519PTI gaskets (standard gasket) and guess what? Same deal, worse actually. I wish I kept my original head gaskets to compare, the witness marks on the 906 heads from the original 1967 date coded gaskets look like it wasn't interfering before but of course the marks are from the embossings. I ran a set of that same gaskets I believe when fixing a burned valve on a buddy's 383 over the summer. I had bought them 3 years ago, but it was the same kit. I'm ashamed to say I never checked the fitment to the head, or if I did I don't recall seeing this, but it was the same kit and I assume the same gaskets. Is this okay? Should I mod the gasket? Anyone else know anything or noticed this before? I can't be the only one. I don't see how it could be okay its blocking a head to block passage, but my buddy's 383 didn't have any cooling issues. On a side note my first combustion chamber CC'd 79 cc
Re: Head Gaskets Block Coolant Passages
[Re: GTX MATT]
#1418038
04/11/13 02:59 AM
04/11/13 02:59 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
The restrictions in the gaskets are there to slow the coolant down so the there is better heat transfer to the coolant.
I am truckless..
[Re: GTX MATT]
#1418040
04/11/13 06:35 AM
04/11/13 06:35 AM
Posts: 21,071 Niles , Ohio
therocks
Niles , Ohio
I agree install them.Why try to out figure the factory engineers.Rocky
Chrysler Firepower
[Re: GTX MATT]
#1418042
04/11/13 10:31 AM
04/11/13 10:31 AM
RapidRobert
go to www.moparchat.com then scroll down to & click on "circle track chat" then peruse Sanborns' cooling mods that are in a sticky at the top & that info may better help you make an informed decision. He's a SB guy but the info is still applicable to BB's with some differences.
[Re: TooMany62s]
#1418048
04/11/13 11:38 AM
04/11/13 11:38 AM
Posts: 75,004 U.S.S.A.
JohnRR
U.S.S.A.
Those big holes are sized that way to get the sand out of the casting in the foundry. This is true of both the block and the heads as they are "sand castings". The gasket reduces them to what they should be for cooling. I never tried opening them all up to the casting size to see what would happen.
I agree with this but the fly in the ointment is that around 1973 they changed the holes in the block to a figure 8 shape which ends up having a round hole right in line with the round hole in the head, BUT they changed the gasket from the rectangle to a slit.
[Re: 80fbody]
#1418049
04/11/13 11:40 AM
04/11/13 11:40 AM
JohnRR
U.S.S.A.
Dis-similar metals, aka steel & aluminum, don't generally mix well. Not sure the technical term but over time the steel sort of eats into the aluminum head surface. Also the steel gasket is a harder material than the aluminum head which means the gasket could imprint itself into the head.
Doesn't seem worth the risk with high dollar heads.
BUT BUT BUT ....
People run MLS Cometic gaskets with alum heads ??????
The fire ring , if that is what it is called , on a felpro gasket is STEEL ????
Coat the gasket with copper spray and he should be fine ...
[Re: 80fbody]
#1418051
04/12/13 01:13 AM
04/12/13 01:13 AM
JohnRR
U.S.S.A.
Can't ... resist ...
He doesn't have High Dollar Heads ...
[Re: JohnRR]
#1418052
04/12/13 03:31 AM
04/12/13 03:31 AM
Posts: 4,848 Memphis
HemiRick
Memphis
Ive been running a set of steel shims under alum heads for 6+ yrs now with no problems at all.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
