Re: Adding front sway bar - 70 Cuda
[Re: JDMopar]
#14171
01/25/05 10:03 PM
01/25/05 10:03 PM
Posts: 1,913 Brunswick, Jawgia
Snailpower
Infinitely Fast Snail
Brunswick, Jawgia
I will be adding a sway bar to the front and rear of mine in the next couple of weeks, and I don't have the tabs either. I had planned on making them, but if there is a company that already has them made, it would save some work.
70 Coronet- turbocharged 360/518/3.73 SG
[Re: JDMopar]
#14173
01/25/05 11:08 PM
01/25/05 11:08 PM
Correct me if I am wrong but I believe Addco's front sway bar kit is a direct bolt on kit and doesn't require any tabs to be made. Summit part# aco-595g
[Re: MaxCuda]
#14175
01/26/05 12:29 AM
01/26/05 12:29 AM
not to hijack this tread..... but...
I've got a 72 Challenger Rally parts car with front and rear sway bars. Didn't all e-bodies come with sway bars? Are these a factory option with the rally and are they worth taking off and saving? Will I have to also save the control arms?
[Re: MaxCuda]
#14177
01/26/05 08:45 AM
01/26/05 08:45 AM
Posts: 568 Ormond Beach, FL
71STROKERFISH
Ormond Beach, FL
I recently added front and rear sway bars to my 71 Cuda. I bought some ebay LCA's(cheap)and cut the mounting brackets off, welded them only mine. They are very easy to locate since they are right next to a large fastener, and butted up to the top of the LCA.
Check out ebay or TENHemi who previously posted. I added an ADDCO front/rear bar to my 74 Duster years ago. All I remember is drilling in the LCA's to mount their supplied bracket. It worked. Good luck!
-dc SOUTHERNPLAINSMOPAARFEST.COM 2018 Jeep Trackhawk 1994 Jeep Grand Cherokee, 5.2 AWD-Daily grinder since 1997 1971 Barracuda, 414ci, 6bbl Fitech, 727 1970 Barracuda Convertible, 472 Ray Barton Hemi, 727
[Re: 71STROKERFISH]
#14178
01/26/05 02:13 PM
01/26/05 02:13 PM
Posts: 9,982 Ansonia, CT
CJK440
Ansonia, CT
I put an aftermarket bar on mine that I got through PST.
It has brackets that mount to the stock K-frame position and the bar goes through the K frame itself. It came with beefy bolt on tabs that you could easily weld in addition to the bolt.
I think the bar is 1"
2017 Contusion Blue Challenger T/A 392 M6 "BLKNBLU"
[Re: jml19621]
#14180
01/26/05 11:46 PM
01/26/05 11:46 PM
Posts: 1,255 Slidell, LA
Ronnman
Slidell, LA
bracket drawing copied from another post.
Ron
See attachment
[Re: Ronnman]
#14183
01/27/05 08:58 AM
01/27/05 08:58 AM
71STROKERFISH
Ormond Beach, FL
Man that is some awesome fabrication!!!!
