Max Torque RPM vs Stall rpm #1417832
04/10/13 06:21 PM
04/10/13 06:21 PM
ont,canada
mopartuner Offline OP
ont,canada
My new combo should make my converter stall at about 4400 rpm so where should the motor make its maximum torque?My converter is a 9.5 inch 904 trans w/low ist gear and the converter is fairly tight.
410 pump gas solis flat tappet cam 10.95 so far
Re: Max Torque RPM vs Stall rpm [Re: mopartuner] #1417833
04/10/13 09:00 PM
04/10/13 09:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Based on the 4400 number you should make peak torque
at 4100-4200 rpm... at least most conv shops say this
