Question on a 750 vacum seconday carb... #141754
10/26/08 05:32 PM
10/26/08 05:32 PM
Lebanon ,PA in the Susquehanna...
70Challengerse Offline OP
Went to change the spring on the secondaries, loosened the electric choke and remove the vacum diaphragm, turned it over....found a check ball on my bench....didn't ever remember them having that..New carb never used Holley 750 vacum secondary...
Re: Question on a 750 vacum seconday carb... [Re: 70Challengerse] #141755
10/26/08 05:45 PM
10/26/08 05:45 PM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
look in the spring houseing. you will see the 4 screw holes and one air hole. the ball goes in there...
I am truckless..
Re: Question on a 750 vacum seconday carb... [Re: 340SHORTY] #141756
10/26/08 05:50 PM
10/26/08 05:50 PM
Thank you....
