70 Challenger - turn signal, 4-way flash problems #141676
10/26/08 02:59 PM
10/26/08 02:59 PM
Williamsport, PA
Rob440Magnum Offline OP
mopar addict
mopar addict
Williamsport, PA
My buddies recently restored 70 Challenger has a problem with the turn signals and 4-way flashers. When you turn one of them on they work fine when looking at the signals outside of the car. Inside the car on the light in the dash they work fine for about 10 seconds and then they start missing blinks and eractic blinks. Outside the car they always work fine. Any ideas?
Thanks, Rob
Re: 70 Challenger - turn signal, 4-way flash problems [Re: Rob440Magnum] #141677
10/26/08 03:34 PM
10/26/08 03:34 PM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Sounds like a dash bulb or grounding issue...
