dash repair #141616
10/26/08 12:05 PM
10/26/08 12:05 PM
Brandon, Ms
cornet684me Offline OP
Brandon, Ms
i have a 1968 dodge coronet with standard dash, my problem is with the lower dash pad, the dash pad is in excellent condition, however a mouse has chewed a small hole on the lower pad right above the switch panel, the top layer of the pad is chewed off down to the sponge, only the size of a penny , can this be fixed? and how can i fix with the pad still in the car?
Re: dash repair [Re: cornet684me] #141617
10/26/08 12:07 PM
10/26/08 12:07 PM
Brandon, Ms
Brandon, Ms
i tried to list a pic. however would not come thru
sorry, i will have to just describe it, it is a chew place about the size of a penny, how to fix
Re: dash repair [Re: cornet684me] #141618
10/26/08 12:53 PM
10/26/08 12:53 PM
englewood beach, florida
ts70rt Offline
ts70rt  Offline
I have used shoe goop (glue made for rubber and plastic shoes)and it has come out great. Fill the hole with the shoe goop (sold at ace 5.00) put electrical tape over the glue to hold the glue straight. Re dye with duplicolor vinyl paint.
Re: dash repair [Re: ts70rt] #141619
10/26/08 03:22 PM
10/26/08 03:22 PM
Brandon, Ms
Brandon, Ms
are you serious? can you send me a pic of what it looks like, i have been told they have a kit
you can buy, and use a heat gun
