Can longer plug wires lead to LATE firing ?? #1415728
04/07/13 02:11 AM
04/07/13 02:11 AM
Granite Bay CA
Kern Dog Offline OP
Striving for excellence
Kern Dog  Offline OP
Granite Bay CA
Maybe a theoretical question since electricity travels so fast, but...
In big block engines, #2 and #4 are really close to the distributor. numbers 5 and 7 are the furthest away. At high rpm is is at all possible that they are receiving the spark later than #s 2 and 4?
Re: Can longer plug wires lead to LATE firing ?? [Re: Kern Dog] #1415729
04/07/13 02:22 AM
04/07/13 02:22 AM
Florida STAYcation
dOc ! Offline
The village idiot's idiot
dOc !  Offline
Florida STAYcation
F-berri ..... do you stay up at nite THINKING about Q's like this ??...
Re: Can longer plug wires lead to LATE firing ?? [Re: Kern Dog] #1415730
04/07/13 02:39 AM
04/07/13 02:39 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
I think the answer is yes, but the difference will be vary, vary small?
Re: Can longer plug wires lead to LATE firing ?? [Re: 451Mopar] #1415731
04/07/13 02:45 AM
04/07/13 02:45 AM
Florida STAYcation
dOc ! Offline
dOc !  Offline
Florida STAYcation
at 186,000 miles per second(or there abouts) ....vary VARY s m a l l !
Re: Can longer plug wires lead to LATE firing ?? [Re: Kern Dog] #1415732
04/07/13 02:46 AM
04/07/13 02:46 AM
Washington State
70Duster440 Offline
70Duster440  Offline
Washington State
Re: Can longer plug wires lead to LATE firing ?? [Re: 70Duster440] #1415733
04/07/13 02:50 AM
04/07/13 02:50 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
make sure you time your engine using the longest spark plug wire...and you will never have late timing.....
Tony
70 AARCuda Vitamin C
Re: Can longer plug wires lead to LATE firing ?? [Re: 70AARcuda] #1415734
04/07/13 05:55 AM
04/07/13 05:55 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
I am truckless..
Re: Can longer plug wires lead to LATE firing ?? [Re: 70AARcuda] #1415735
04/07/13 08:52 AM
04/07/13 08:52 AM
Marysville, O-H-I-O
70Cuda383 Offline
70Cuda383  Offline
Marysville, O-H-I-O
but the what do you do about the shortest plug wires? they'll be premature.
I like to use all the same length spark plug wires because of this. works incredibly well on my 4.7, keeping all the sparks in time.
**Photobucket sucks**
Re: Can longer plug wires lead to LATE firing ?? [Re: 70Cuda383] #1415736
04/07/13 09:59 AM
04/07/13 09:59 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I eqiuallze all my plug wires with no sharp turns.
Re: Can longer plug wires lead to LATE firing ?? [Re: 70Cuda383] #1415737
04/07/13 10:02 AM
04/07/13 10:02 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I eqiuallze all my plug wires and make sure no sharp turns.
Re: Can longer plug wires lead to LATE firing ?? [Re: Kern Dog] #1415738
04/07/13 10:21 AM
04/07/13 10:21 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
you guys make me laugh since electricity travels 186,000 miles a second it travels 186 miles in 1000th of a second which is 982,080 feet per 1000th of a second say the longest to shortest plug wire is 2 feet longer that would take 1/491040 of 1/1000 of a second to travel that extra 2 feet.
now if you had a plug wire or two that reached around the world so one plug wire 2 feet long and one 24000 miles long (whats that something like 126,000,000 feet?? ) it would take .129 seconds longer to get to the cylinder.
Re: Can longer plug wires lead to LATE firing ?? [Re: Kern Dog] #1415739
04/07/13 10:34 AM
04/07/13 10:34 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
If your worried about dirty wires slowing down the spark get a set of these
http://kalecoauto.com/index.php?main_page=product_info&cPath=9&products_id=27
and why bother degreeing a cam now that these are available
and boost your power with one of these
http://kalecoauto.com/index.php?main_page=product_info&cPath=12&products_id=49
and when your done use the all new butt dyno to see what the improvements did
http://kalecoauto.com/index.php?main_page=product_info&cPath=6&products_id=8
Re: Can longer plug wires lead to LATE firing ?? [Re: Dodgem] #1415740
04/07/13 10:41 AM
04/07/13 10:41 AM
Bitopia
jcc Offline
jcc  Offline
Bitopia
you guys make me llaugh
I thought that was whole point
Re: Can longer plug wires lead to LATE firing ?? [Re: jcc] #1415741
04/07/13 10:46 AM
04/07/13 10:46 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
well it brightened up my morning for sure! :-)
Re: Can longer plug wires lead to LATE firing ?? [Re: jcc] #1415742
04/07/13 10:47 AM
04/07/13 10:47 AM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
And you really have to watch fuel line routing,liquid flows faster down than up ! I know,it's under pressure so it doesn't matter .
Re: Can longer plug wires lead to LATE firing ?? [Re: Dodgem] #1415743
04/07/13 11:00 AM
04/07/13 11:00 AM
Blairsden, CA
Triggerfish Offline
Triggerfish  Offline
Blairsden, CA
Simple solution...just use a smaller gap on the plugs with the longer wires...or, get the Accel shorties...
Re: Can longer plug wires lead to LATE firing ?? [Re: Kern Dog] #1415744
04/07/13 11:03 AM
04/07/13 11:03 AM
USA
3
360view Offline
Moparts resident spammer
360view  Offline
3
USA
The question is not silly
all real world electrical circuits
have some
resistance
capacitance
inductance
if the ignition wires used
have appreciable
capacitance and/or inductance
then this will delay in time
the build up of
"flashover voltage"
at the spark gap
the delay is not due to a change in the speed of light
but because of the time to build up
stored energy in capacitive or inductive fields
typical carbon core factory ignition wires
will not have much capacitance or inductance
.. but can have enough capacitance to cause
"crossfire"
to a nearby wire from another cylinder's
if they run close and parallel
Chrysler has had problems with this:
http://dodgeram.info/tsb/1998/18-48-98.htm
spiral wound metal core
low RFI design ignition wires
will have more measured inductance
but the design is an inherently bad
"antenna"
for high frequency AC
aircraft gasoline engine ignition wires
can be fully covered by a shield
for RFI reasons
and might measurably slow down
the speed at which flashover voltage builds up
but this is understood and compensated for
as an extreme experiment
if you took an
extra long solid metal core ignition wire
and wrapped it numerous times
around an iron bar midway
before connecting it to the sparkplug
the delay would be as great as practical
and spark burn time would be extended somewhat
as the inductive fields discharged as the current declined
Re: Can longer plug wires lead to LATE firing ?? [Re: 62maxwgn] #1415745
04/07/13 11:04 AM
04/07/13 11:04 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
I like to use equal length wires and wrap the extra wire around empty toilet paper tubes which slip over a toilet plunger that I stick to the inner fender. That way you don't kink off the electricity
1969 Hemi Roadrunner 2nd owner
Re: Can longer plug wires lead to LATE firing ?? [Re: 360view] #1415746
04/07/13 11:29 AM
04/07/13 11:29 AM
South-Central (Sebring), FL
Commando1 Offline
Commando1  Offline
have some
resistance
capacitance
inductance
have appreciable
the build up of
"flashover voltage"
at the spark gap
"crossfire"
"antenna"
for RFI reasons
if you took an
You weren't suppose to take him seriously...
Re: Can longer plug wires lead to LATE firing ?? [Re: 360view] #1415747
04/07/13 11:45 AM
04/07/13 11:45 AM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
have some
resistance
capacitance
inductance
have appreciable
the build up of
"flashover voltage"
at the spark gap
"crossfire"
"antenna"
for RFI reasons
if you took an
Thanks, Professor
Way to ruin a useless thread, lol.
Don't be the exception.
