440 block #1415033
04/05/13 09:18 PM
04/05/13 09:18 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Hi. What year of 440 block should I be looking for to put in a 65 Belvedere, what to make top end Max Wedge Cross Ram. Thanks
Re: 440 block [Re: 300_dup5] #1415034
04/05/13 09:48 PM
04/05/13 09:48 PM
As far as block integrity any year would work fine. Other than a basic 30 over rebuild you could magnaflux/sonic check/water pressure check to confirm your starting with a good foundation. You might read Andy's thin wall debunk info in the archives
Re: 440 block [Re: RapidRobert] #1415035
04/05/13 09:55 PM
04/05/13 09:55 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Thanks. I,ll read that, Just thought pre 70 would be better
Re: 440 block [Re: 300_dup5] #1415036
04/06/13 10:01 AM
04/06/13 10:01 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
69 1/2 and up are actually better as they added a stiffening rib to the side of the block in 1969 to help prevent cracking between the frost plugs.
other than a bad block with a lot of core shift (can happen in any year) later are dang good blocks!
Re: 440 block [Re: 300_dup5] #1415037
04/06/13 10:55 AM
04/06/13 10:55 AM
Holly/MI
Dean_Kuzluzski Offline
Holly/MI
Take the time to read this info from 440 Source............
http://www.440source.com/blockinfo.htm
It talks about the better "main saddle support", as cast, when each block is poured.
Re: 440 block [Re: Dean_Kuzluzski] #1415038
04/06/13 06:31 PM
04/06/13 06:31 PM
Ontario Canada
3
300_dup5 Offline OP
300_dup5  Offline OP
Ontario Canada
Thanks for that info
Re: 440 block [Re: 300_dup5] #1415039
04/06/13 07:40 PM
04/06/13 07:40 PM
Holly/MI
Holly/MI
Glad to help out.
