72-93 dodge cabs #1414835
04/05/13 09:38 AM
04/05/13 09:38 AM
st.cloud fl
d-150 Offline OP
Smarter than a 5th grader?
d-150  Offline OP
st.cloud fl
Going to change a cab out of my 77 dodge truck.what years are the cabs.interchange?
Re: 72-93 dodge cabs [Re: d-150] #1414836
04/05/13 11:27 PM
04/05/13 11:27 PM
Waynesboro PA 17268
RODHALL Offline
RODHALL  Offline
Waynesboro PA 17268
72-80 cab.
81-84 must use glass from cab. body line at back of cab, wiring bulkhead different..
85-93 move door striker..
81 the back window opening changed, was made taller and wider. wiring blukhead was changed to a square.body line was moved down. 85 the door striker was moved up higher. 2wd all have the same hump.. 4x4 70's used bolt in hump 80 stamped in floor hump. have to be willing to oval out the shifter hole depening on the transfer...
With minor mods these swaps can keep older trucks running.
Re: 72-93 dodge cabs [Re: RODHALL] #1414837
04/05/13 11:57 PM
04/05/13 11:57 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
I used an 83 back window in my 73. Pulled it itself.
Re: 72-93 dodge cabs [Re: RODHALL] #1414838
04/06/13 12:01 AM
04/06/13 12:01 AM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
um I put a back glass from a 86 parts truck to a 79 warlock without any problems?? only difference is some are thicker than others
The door striker didn't move either it was a smaller design than the thicker 85-earlier versions because I installed doors off a 86 parts truck onto my 81 stepside and had to use the 86 strikers, but they are in the same location, not trying to make anyone upset, but I've done this swap many times without any problems on these trucks.
Re: 72-93 dodge cabs [Re: RODHALL] #1414839
04/06/13 12:02 AM
04/06/13 12:02 AM
Pyeongtaek, South Korea
69HemiGTX Offline
69HemiGTX  Offline
The roofline of the regular cab was also different. It was much more square above the rear window when viewed from the side. The club and crew cabs had the same profile as the 72-80 cabs.
OIF V and OEF X veteran and proud of it!
Re: 72-93 dodge cabs [Re: 69HemiGTX] #1414840
04/06/13 04:18 AM
04/06/13 04:18 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
So far as I know for a fact
The steering column mount changed in 1979 stayed that way till the end
The diameter of the striker changed in 1985
The heater box opening changed in 1979
If you have a stick you need a stick hump (NP435)
Wiper linkage changed in 1975
Rooflines changed of course
That's all I can remember off the top of my head for now
Re: 72-93 dodge cabs [Re: BulletBob] #1414841
04/06/13 05:29 AM
04/06/13 05:29 AM
Winnipeg, Manitoba, Canada
4dr4x4 Offline
mopar addict
4dr4x4  Offline
mopar addict
The early cabs had the gas tank behind the seat and a slightly different dash.
Re: 72-93 dodge cabs [Re: 4dr4x4] #1414842
04/07/13 01:00 PM
04/07/13 01:00 PM
South East Ontario, Canada
Ramtough Offline
Ramtough  Offline
Rear window in a 72- 4 is 2" narrower than 75-93.
Did a custom job on a 74 back in the late 70's, only one person some what nailed year of truck, well experienced glass guy that knew mine had the narrow rear glass.
Re: 72-93 dodge cabs [Re: Ramtough] #1414843
04/07/13 01:30 PM
04/07/13 01:30 PM
Iowa
76dodgeboy Offline
76dodgeboy  Offline
Iowa
My 73 Had a 85 Back window
I've had 74s with and without in cab tanks.
Re: 72-93 dodge cabs [Re: 76dodgeboy] #1414844
04/08/13 12:35 AM
04/08/13 12:35 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
My 73' Pro Streeter had a Limo tinted 77' back glass I would have put an 87' in it that I tinted 1st but it was too thin for the gasket
Re: 72-93 dodge cabs [Re: BulletBob] #1414845
04/11/13 05:20 PM
04/11/13 05:20 PM
st.cloud fl
d-150 Offline OP
d-150  Offline OP
st.cloud fl
ok,so if i go with 93 cab i just have to put 77 firewall in?
Re: 72-93 dodge cabs [Re: d-150] #1414846
04/11/13 06:13 PM
04/11/13 06:13 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
To use your 77 model heater box & steering column you do
Re: 72-93 dodge cabs [Re: BulletBob] #1414847
04/11/13 07:05 PM
04/11/13 07:05 PM
st.cloud fl
d-150 Offline OP
d-150  Offline OP
st.cloud fl
10-4 thanxs
