Re: edel victor oil drain hole blocked [Re: MR_P_BODY] #1414264
04/04/13 11:12 PM
04/04/13 11:12 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Do what you want to.. doesnt matter
then why did you say something.
Re: edel victor oil drain hole blocked [Re: Clanton] #1414265
04/05/13 12:33 PM
04/05/13 12:33 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
some info on oil drain angle.just fyi take from it what you will.
Re: edel victor oil drain hole blocked [Re: Clanton] #1414266
04/05/13 12:34 PM
04/05/13 12:34 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
angle2
Re: edel victor oil drain hole blocked [Re: Clanton] #1414267
04/05/13 02:00 PM
04/05/13 02:00 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It looks good
Re: edel victor oil drain hole blocked [Re: MR_P_BODY] #1414268
04/05/13 04:05 PM
04/05/13 04:05 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thanks but I think I am going to take more out of the drain hole,bigger.
Re: edel victor oil drain hole blocked [Re: Chris'sBarracuda] #1414269
04/05/13 04:21 PM
04/05/13 04:21 PM
Overpriced Housing Central
RobX4406 Offline
RobX4406  Offline
I spoke to an Edelbrock engine builder at The MATS and he said they were making some changes to the Victor Heads, especially the push rod problems..
Chris..
Be nice of they fixed some of the F-ups they made to the bare casting when changed to heart shaped chamber.
They messed up the port shapes so badly in the new revisions. Need to go back to the older port, heart shaped chamber and fix push rod clearance issues.
The head worked well with the old port, now they need a bunch of porting to flow any kind of decent numbers.
Re: edel victor oil drain hole blocked [Re: RobX4406] #1414270
04/05/13 04:29 PM
04/05/13 04:29 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
WOW!I am sure I got an old set then.casting # 29711]I would like to open the oil drain more but while consulting on that I am shimming the rockers.
Re: edel victor oil drain hole blocked [Re: Clanton] #1414271
04/05/13 05:10 PM
04/05/13 05:10 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
just like the drive half a bbl off.
