Hi Guys,
Im a Ford and MGB guy but have always loved Mopars.
Recently Ive come across a 68 Polara 4 door and need to know what areas should I be especially concerned. This has:
1. a fresh 318
2. Original paint that with areas of nicks and surface rust - no bubbling can be detected
3. Solid quarters
4. Trunk has a fair degree of surface rust with a 6x6 inch area of pin holes on the DS of the gas tank
5. Old bed liner material that was sprayed in trunk is present
6. Frame looks solid, areas of surface rust also noted
7. R passenger window regulator is not working
8. Headliner is torn
9. Carpets and seats are shot
10. Lots of play in the column shifter (hard to tell when in gear)
11. Neutral safety switch needs attention (only can start in N)
12. Dash pad needs replacing
13. Cowl vents looks solid but havent pured water in them yet
14. Floor boards look solid also
15. Front suspension/rear is very dated and prob will need a rebuild + new leafs...
So what other areas should I look at?
Also I know that parts for C-bodies are tough to come across - so Im a bit cautious here d/t part availability.
Ive done restoration work before but not on Mopars (just finished a 68 mustang ..http://s1064.photobucket.com/user/ToneMt/library/)
Here are some pics:
[url=[URL="http://s1064.photobucket.com/user/ToneMt/library/"]http://s1064.photobucket.com/user/ToneMt/library/[/URL]]Photobucket[/url]
