Page 1 of 3 1 2 3
34 Dodge Update #1413367
04/01/13 11:13 PM
04/01/13 11:13 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
I haven't posted in awhile. Personal things going on. I finally got some time to wind down and work on the car. I decided a couple of weeks ago to strip my car to bare metal. I have been hesitant to do this, afraid of what I would find. The car actually looked pretty good so I thought I could get away with just doing a little body work and painting it. Long story short, I'm glad I stripped it even though it will require much more work. There was some known rust in front of the trunk lid that needed to be taken care of. My sheet metal fabricator came over and got to work makeing a patch panel and reconstructing the drip rails inside the trunk lid. These had been mostly cut out by a previous owner. I wish I had the tools to do this myself. The shrinker/strecher intriques me. There were also some major indentations maybe 3/4" deep, that he noticed right away that had been filled with lead. He says that this was not uncommon from the factory and they just filled them rather than pound them out. Anyone have experience with that? Anyway, Here are acouple of pics, one before and one after some time making and fitting parts.
Re: 34 Dodge Update [Re: B1arno] #1413368
04/01/13 11:14 PM
04/01/13 11:14 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
With new parts.
Re: 34 Dodge Update [Re: B1arno] #1413369
04/02/13 08:37 AM
04/02/13 08:37 AM
Joplin, MO USA
Robbins Offline
Robbins  Offline
Joplin, MO USA
Awesome! Looking good!
Moparlee
Re: 34 Dodge Update [Re: B1arno] #1413370
04/02/13 09:05 AM
04/02/13 09:05 AM
Ontario Canada
Webster Offline
Webster  Offline
Ontario Canada
Looking good....Some Big Booties going on her by the looks of the tubs
Re: 34 Dodge Update [Re: B1arno] #1413371
04/02/13 09:48 PM
04/02/13 09:48 PM
moparx Offline
moparx  Offline
arno, my humpback has major "divots" under the leadwork where the roof panels meet the a pillars, and where the roof and b pillars meet. this is a very common thing found under the lead joints. i can see similar "workmanship" in the rear by the door opening and 1/4 panel joints, but the lead is still in the joints on the outside, but cracked pretty good. i'm sure there will be a mess as i expect under the lead. you will be glad you took the time to strip and repair properly in the long run.
Re: 34 Dodge Update [Re: Webster] #1413372
04/02/13 11:00 PM
04/02/13 11:00 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Thanks guys! For those that may be new on here, this is a pic of the chassis from some time ago. Just working on the body now.
Re: 34 Dodge Update [Re: moparx] #1413373
04/02/13 11:10 PM
04/02/13 11:10 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Thanks Moparx. It just seems odd that assembling all new parts freshly stamped that there would be this kind of damage, but apparently it happened. Oh well, fix it and move on. With a little luck and a lot of time, and if life doesn't get in the way, I might have it on the road by years end.
Re: 34 Dodge Update [Re: B1arno] #1413374
04/10/13 10:44 PM
04/10/13 10:44 PM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
Good job Arno,
It's going to be an awesome coupe!
Keep up the good work.
Mark
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: 34 Dodge Update [Re: Hemi Allstate] #1413375
06/30/13 08:50 PM
06/30/13 08:50 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
A little more progress. More rust repair and PO crumby work repair. It's slow going but I feel confident it will be a much nicer car when I'm done because of it. I cut the roof plug off of it and am redoing it. They just lapped it on top of the existing sheet metal, tack welded it, and buried it in fiberglas. A few pics.
Re: 34 Dodge Update [Re: B1arno] #1413376
06/30/13 08:51 PM
06/30/13 08:51 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Another.
Re: 34 Dodge Update [Re: B1arno] #1413377
06/30/13 08:52 PM
06/30/13 08:52 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Patch panel in front of rear wheel opening.
Re: 34 Dodge Update [Re: B1arno] #1413378
06/30/13 10:13 PM
06/30/13 10:13 PM
moparx Offline
moparx  Offline
good deal arno ! was your roof skin just laying on top of the roof with the padded top channel under it ? nice job on the 1/4 patch !
Re: 34 Dodge Update [Re: moparx] #1413379
06/30/13 11:12 PM
06/30/13 11:12 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
Yeah, it was just laid on top and tack welded in position. It looks like they used a roof section out of a minivan or suv with stiffening ribs in it so there was no bracing underneath to hold it up. It looked a bit funny because pretty much every panel on the car is rounded and the roof ended up flat across the top.
Did you ever get the mig welder light? If so, does it help?
Re: 34 Dodge Update [Re: B1arno] #1413380
07/01/13 11:39 AM
07/01/13 11:39 AM
Mt. Eden Ky.
Mt. Eden Ky.
Looking Good Arno!
Keep the pictures coming too.
1996 Ram 1500 Sport
1968 road runner
Re: 34 Dodge Update [Re: B1arno] #1413381
07/01/13 09:23 PM
07/01/13 09:23 PM
moparx Offline
moparx  Offline
i rigged up a cheapo led pocket flashlite to try out the idea first. i just tried a couple of tacks and the jury is still out. i have a project i hope to do this coming weekend which will require some extra light. if it helps, i'll let you know !
Re: 34 Dodge Update [Re: moparx] #1413382
07/03/13 10:32 PM
07/03/13 10:32 PM
in front of the computer
8
80arrow Offline
80arrow  Offline
That looks awesome and like a lot of work, but fun . I wish I had the knowledge, patience, and guts to do a complete project like yours. Any idea what you are going to do with the roof?
Re: 34 Dodge Update [Re: 80arrow] #1413383
07/04/13 12:15 PM
07/04/13 12:15 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
I have a friend with an english wheel. We kind of messed around with it to see what it would take to make a plug for the roof. I need to get the rest of the areas where they screwed up the chop on the roof straightend out before we can make the plug. Then it will be flush welded in.
Arno
Re: 34 Dodge Update [Re: B1arno] #1413384
07/04/13 02:28 PM
07/04/13 02:28 PM
8
80arrow Offline
80arrow  Offline
That will look very nice with the roof filled in. Was that the way they came with an opening in the roof? Mine has about the same hole in the top, they have tinted lexan over it, like a moon roof. I think it would look better to fill it in like you are going to. I'll look for that wiring harness this weekend hopefully, thanks
Re: 34 Dodge Update [Re: 80arrow] #1413385
07/04/13 05:09 PM
07/04/13 05:09 PM
Redwood City Ca.
B1arno Offline OP
B1arno  Offline OP
Redwood City Ca.
It had a fabric covered top originally over a wood framework. I'm not sure why they were done this way. My guess is cost savings in production. Maybe someone else can enlighten us?
Arno
Re: 34 Dodge Update [Re: B1arno] #1413386
07/04/13 05:36 PM
07/04/13 05:36 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
I am liking the looks of that right there. It looks super aggressive. I'd like to do one of these in the future with a 30's Plymouth or Dodge.
Page 1 of 3 1 2 3
