dodge truck #1412051
03/31/13 11:13 AM
03/31/13 11:13 AM
nc
trex Offline OP
trex  Offline OP
nc
i have a 85 dodge ram truck slaint six 4 speed 4 wheel drive and i want to put a 318 motor in it what do i need? thanks for your help
Re: dodge truck [Re: trex] #1412052
03/31/13 11:50 AM
03/31/13 11:50 AM
Truck SB mtr mts. 4wd 4sp SB bell. I'm assuming /6 & SB flywheels are different. I'm not a truck guy so this is more of a BTT for ya. You sure you dont want to put a 360 in there? I wouldn't think the 318 would be any gain
Re: dodge truck [Re: RapidRobert] #1412053
03/31/13 08:30 PM
03/31/13 08:30 PM
scratchnfotraction Offline
SB engine brackets..use stock rubber biscut mounts.
SB bell/flywheel..use same clutch disc/throwout bearing.
SB truck manifolds or SB 4x4 headers.
SB rear sump oil pan/pick up tube.
SB power steering pump and brackets
SB alt brackets..use stock alt.
SB engine pullys/belts
SB dist
SB upper/lower rad hoses/V-8 rad shroud..use stock rad
SB intake throttle bracket.. use stock throttle cable
the /6 wire harness needs trimed and re-routed for V-8 hook up, very simple and ez to do.
318/360 use different oil pans so you need the right one for engine size you pick.
Re: dodge truck [Re: scratchnfotraction] #1412054
03/31/13 10:12 PM
03/31/13 10:12 PM
Scratchn is the man
Re: dodge truck [Re: trex] #1412055
04/01/13 08:26 PM
04/01/13 08:26 PM
Alexandria, NJ
WayneM Offline
WayneM  Offline
Alexandria, NJ
Can't remember that last time I saw one of those... Nice project though.
2014 Durango R/T
2004 Dodge Ram 3500 SRW SLT short quad Cummins 6 speed
1998 Dodge Durango SLT 5.2
1971 Plymouth Duster-
<<<<<MOPAR SPOKEN HERE>>>>>
Re: dodge truck [Re: WayneM] #1412056
04/01/13 11:35 PM
04/01/13 11:35 PM
Salem
Grizzly Offline
Moparts Proctologist
Grizzly  Offline
Salem
Meh, chuck a $200.00 turbo from the classifieds on there and you'll be laughin'.
Mo' Farts
Moderated by "tbagger".
Re: dodge truck [Re: Grizzly] #1412057
04/01/13 11:50 PM
04/01/13 11:50 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Watch putting the 360 in. The flywheel alone is a lot more expensive than the 318 one. (360 is externally balanced) I have everything you need if you want to do a 360. Bell I have is for a granny gear trans from a 3/4 ton pu. I'm getting ready to part out a 91 that rust has ruined.
...FAFO...
