x heads question
#1411856
03/31/13 12:39 AM
03/31/13 12:39 AM
Posts: 755 Tri Cities TN area
Hailtheleaf538
Never Misses A Coffee Break
Tri Cities TN area
Hey all....getting back into the Mopar hobby after not having owned a classic one in year. I do have a new Jeep Liberty if that counts... Anyway, Im looking at buying a 1970 swinger 340. Went and looked at it today. checked the vin number and the fender tag, its an original 340/727 Top Banana car built in Canada, with an original go wing, front discs, and not much else in the way of options. The owner claims it came from the factory with a 904, I didn't want to argue and tell him it didn't but that's another story. Not that important to me anyways, want to build a street/strip car r. I figured the 727 went out years ago, and that's what was in it when he got it. I want to build a street/strip car out of it. My question concerns the heads. I was reading earlier that some x heads came with a U or an O. One has a U and the other has an o where there would be an X. On the front of the heads, there is an (I) symbol. More like a straight up and down line, but ya know. Motor is all orange, and under a lot of grease.....It runs and drives, hope to drive it next week when the owner gets back in town (wasn't there today)It's mine as far as im concerned either way,......the price is CHEAP by today's standards for an original 340 car. Any info is appreciated fellow Mopar fans.....thanks!
Organized Labor: The people that brought you the weekend.
If you can't grasp the meaning of the phrase "tongue in cheek", don't respond.
1970 H code Swinger, Top Banana
2012 Liberty Jet 4x4 True Blue Pearl
Re: x heads question
[Re: Hailtheleaf538]
#1411859
03/31/13 01:42 AM
03/31/13 01:42 AM
Posts: 12,291 Kent, Wa
340SHORTY
Truck Nut
Truck Nut
Kent, Wa
There are X, O, U and some J heads that had 2.02 intake valves. Then there a J heads with the 1.94 intake valves, all have the 1.60 exhaust valve. All of these heads are the "915" castings. I happen to have 1 X and 1 O head on my 340, as they are both 2.02s it doesnt bother me.
I am truckless..
[Re: Jim_Lusk]
#1411860
03/31/13 01:44 AM
03/31/13 01:44 AM
Hailtheleaf538
Tri Cities TN area
I just had never seen any without the x cast into them.....or J heads without the J cast into them.....I guess it must be fairly common. thanks for the response......
[Re: 340SHORTY]
#1411861
03/31/13 01:48 AM
03/31/13 01:48 AM
Hailtheleaf538
Tri Cities TN area
Yep, like I said the driver's side has a U, and the passenger side an O on them. Not very important to me either. Im just excited to drive it home, and get back into the Mopar business......have [lans to make fairly quick street legal car out of it, for mostly track time, but that I can drive on the street occasionally. Thanks.
#1411863
03/31/13 12:01 PM
03/31/13 12:01 PM
Posts: 543 Indiana, Just Off I-70
BradD
Depends on the build date of the car. If the car was built between August 1969 and February 1970, I would assume it to have "X" heads. If the car was built after mid February 1970 I would assume it POSSIBLE to have been assembled with a "newer" casting as Chrysler was moving castings toward the 1971 model year.
Brad
Check out the Dorn's 69 Barracuda "Switchblade" in the Nov.2010 MCG Check out the Dorn's refurbished 36 Ford in the Feb.2011 Street Rodder
