Re: Cummins water pump
[Re: Michael]
#1411677
03/31/13 10:27 PM
03/31/13 10:27 PM
moparpollack
Lil Herman
Lil Herman
85086
If you don't use it you lose it!
[Re: Michael]
#1411678
03/31/13 10:27 PM
03/31/13 10:27 PM
Posts: 1,652 Amarillo, Tx
old_goat
Six Abuser
Six Abuser
Amarillo, Tx
You might want to go to a local diesel shop and have the ph tested in the coolant, or at least flush and refill the cooling system. I work in a truck shop, and testing the coolant is routine at every service on over 100 trucks we run. If the levels are too out of whack acidity wise, the water pumps, and even metal coolant lines can corrode quickly. Just good maintenance measures.
84 D150 440/727 79 /6 swb D150 1964 A100 window van. Just because it has spark plug tubes doesn't mean it's a Hemi.
If ya haven't been there, ya just wouldn't understand.
[Re: old_goat]
#1411679
04/01/13 05:14 AM
04/01/13 05:14 AM
Posts: 5,929 Norman, OK
426Savoy
Norman, OK
Good idea. I think the original pump should have lasted longer than 65,000 miles and the replacement 25,000 miles.
[Re: 426Savoy]
#1411683
04/05/13 01:04 PM
04/05/13 01:04 PM
Posts: 2,537 PORT ALBERNI , BC., CANADA
superwrench
290000 Kms when mine went on my 92 CTD. If it wasn't for the stupid tensioner being in the way, at least its only a hours job start to finish with the pain in the butt part being refilling the system. Darn things sure like to air-lock don't they..... Neighbor had a water pump go in his 2005 F350 diesel. He did it himself and I think the truck was down for 2 days!! Should seen his face when he watched me change mine....
[Re: superwrench]
#1411684
04/06/13 10:36 PM
04/06/13 10:36 PM
Posts: 8,681 Buford, GA
I_bleed_MOPAR
Buford, GA
Replaced my '06 last November at 85k. Surprised me how easy it was. Now the belt was another story. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
