I thought that's what mine holds & guess I'll just drain it & count the quarts as I refill to the correct level on the dipstick. I just didn't want to go thru all of that if I could find out how tall a 6 qt pan sump is. Maybe I'll just go over to Summit & measure the MP 6 qt sump. Problem is after changing the heads, cam & rear main seal, I'm trying to chase some small leaks & mistakenly overfilled the pan thinking I was loosing a lot of oil. That really caused huge leakage, so hope I didn't damage anything. Drained 2 qts & that stopped most of the leaks.
