small block pushrods #1409673
03/27/13 01:06 AM
03/27/13 01:06 AM
mn
moparguy93 Offline OP
mn
will stock push rods live in a performance build? 11:1 comp 547/564 lift 1.6 rockers. if not what would be a decent upgrade?
Re: small block pushrods [Re: moparguy93] #1409674
03/27/13 01:14 AM
03/27/13 01:14 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
well..what are you using for rocker arms?
Tony
70 AARCuda Vitamin C
Re: small block pushrods [Re: 70AARcuda] #1409675
03/27/13 01:43 AM
03/27/13 01:43 AM
mn
mn
adjustable stainless steel 1.6 roller rockers. stock size push rods fit perfect. im just wondering if they will last?
Re: small block pushrods [Re: moparguy93] #1409676
03/27/13 02:14 AM
03/27/13 02:14 AM
las vegas
70AARcuda Offline
70AARcuda  Offline
las vegas
all going to depend on spring pressure..
Tony
Re: small block pushrods [Re: 70AARcuda] #1409677
03/27/13 02:17 AM
03/27/13 02:17 AM
mn
mn
seat pressure is 130 and .550lift pressure is 325.
Re: small block pushrods [Re: moparguy93] #1409678
03/27/13 10:51 AM
03/27/13 10:51 AM
Locomotion Offline
Locomotion  Offline
I wouldn't feel comfortable with it. Spending the time & money to put other good performance parts in, then use worn OEM pushrods!?
Re: small block pushrods [Re: Locomotion] #1409679
03/28/13 10:23 AM
03/28/13 10:23 AM
Carson City, NV
babarracuda Offline
babarracuda  Offline
Carson City, NV
Have you checked the roller on the valve? With both my 1.5 and 1.6 rockers I had to get longer pushrods and shim up the shaft to get the proper geometry. If the roller does not stay in the center of the valve stem the geometry is off. The smallest problem will be the guides wearing very quickly. I used 5/16 .085 wall from Smiths. .595 lift 265@ .050 cam.
A shortcut is the fastest way to where you don't want to go!!!
Re: small block pushrods [Re: babarracuda] #1409680
03/28/13 12:38 PM
03/28/13 12:38 PM
Philadelphia
radar Offline
radar  Offline
Philadelphia
1.6 huh? Do they kiss the holes thru the heads? I bought my last set in a chevy flavor because a stock length was perfect for my eddy head prw steel rocker mp solid combo. I got the hardened pushrods 'for use with guide plates'. Of course Im not using steel guide plates with a shaft rocker setup and the pushrod to head contact was very minor but since I'm not taking the head off to clearance it I figured hardened steel against soft aluminum wouldn't be likely to heat up and fail.
Re: small block pushrods [Re: moparguy93] #1409681
03/28/13 12:45 PM
03/28/13 12:45 PM
Columbia, CT
moper Offline
moper  Offline
Columbia, CT
I agree with the above - you spend ont he good stuff then skimp on one of the hardest stressed parts in the engine? Not good. I measure and order from Smith Bros. A high quality pushrod will go a long way to keeping the rest fo the valve train in shape. The wrong one will be "the weakest link".
