Re: Recomend a valley plate for my stealth heads please.
[Re: 64Post]
#1408643
03/26/13 10:28 PM
03/26/13 10:28 PM
Posts: 1,301 Penna
70satelliteguy
Penna
Thanks for the reply 64! I know this is just a simulated installation but I have a few questions. Do you need a special tool to get a 45 degree angle on the tray? What kind of heads are those you show without intake ports? Why do you use tape around the sealer ? In short It looks like you are just making a valley plate out of an original tin gasket Thanks mIke
[Re: BSB67]
#1408644
03/26/13 11:26 PM
03/26/13 11:26 PM
Posts: 8,716 Baltimore/Denver
64Post
Baltimore/Denver
I'm talking cam changes.
Pull the intake, cut/remove the sealer and pop it out with a putty knife. It can be reused over and over and over and over again...
[Re: 64Post]
#1408646
03/27/13 08:51 AM
03/27/13 08:51 AM
Posts: 1,301 Penna
70satelliteguy
Penna
Thanks 64 "Used the red handle tool in pic above to make the 45º bend." What is that tool called so I can get one? Thanks mIke
