Just wondering if I would loose a lot of power and torque going from cheap Hedman Headers to Magnum Manifolds? The application is a early LA 318 with the small Summit Cam, Performer Intake, and 600cfm carburetor with electronic ignition. Pistons and heads are untouched. Car already has dual exhaust 2.5" with Dynomax Ultra Flo mufflers. The car has a 2.76 axle ratio. The main use for partial daily driver duties and road trips. Also, which Magnum Manifolds will work for a 68 B Body application? I have access to a Ram truck, a Ram Van, and several Dakotas mainly 94-98 variety.
Not a fan of headers so, I'm throwing it on the table since to me they look out of a place on a small block B-Body plus these are starting to leak.
