stretch guage #1407086
03/23/13 01:30 PM
03/23/13 01:30 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
can someone recomend a good middle of the road stretch guage?im not a pro i only assemble 1 engine every 2 or 3 years,ive never had a faliure but my power levels have increased and id like to learn to do it RIGHT.the ones at Jegs range from 49 bucks to almost 300.oo,BIG diff.thanks,AJ
Re: stretch guage [Re: bonefish] #1407087
03/23/13 02:18 PM
03/23/13 02:18 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: stretch guage [Re: pittsburghracer] #1407088
03/23/13 02:30 PM
03/23/13 02:30 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
http://www.summitracing.com/parts/arp-100-9942/media/images
i saw that one,have you personally used it?
Re: stretch guage [Re: pittsburghracer] #1407089
03/23/13 02:34 PM
03/23/13 02:34 PM
Delray beach, Florida
P
Performance Only Offline
P
That's a good middle of the road guage. The parallelism is pretty good and should do a good job for you. It's not what i use but I have used that one and it's pretty good. There are cheaper ones, but when it comes to measuring tools you want one that works as intended and is repeatable.
machine shop owner and engine builder
Re: stretch guage [Re: Performance Only] #1407090
03/23/13 02:35 PM
03/23/13 02:35 PM
s.w.fl
bonefish Offline OP
bonefish  Offline OP
s.w.fl
Thats good enough for me.Thanks,AJ
Re: stretch guage [Re: bonefish] #1407091
03/23/13 02:36 PM
03/23/13 02:36 PM
PA.
"Little"John
"Little"John
PA.
I have and it works very good. I used it on my last two builds. I don't think that any of them are really easy to use but its the proper way. Next build I am going to weld a cheater to a box wrench and see how that goes. Probably do it to a ratcheting box wrench.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: stretch guage [Re: pittsburghracer] #1407092
03/23/13 02:38 PM
03/23/13 02:38 PM
PA.
"Little"John
"Little"John
PA.
Make sure when you buy one it goes to .0005 and not .001
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: stretch guage [Re: pittsburghracer] #1407093
03/23/13 08:56 PM
03/23/13 08:56 PM
western pennsylvania
b1dartsport Offline
b1dartsport  Offline
That exact stretch gauge is for sale right now on the board in Tools/equipment/Trailers for sale for $135
Re: stretch guage [Re: b1dartsport] #1407094
03/23/13 10:15 PM
03/23/13 10:15 PM
communist bloc of new jersey
jamesc Offline
jamesc  Offline
imho most if not all of the commercially sold gauges use a poor quality indicator. i elected to buy the frame off ebay and use a good mitutoyo digital indicator. you also want to make sure the indicator has enough spindle pressure to seat the tip securely
this is the frame
http://www.ebay.com/itm/Rod-Bolt-Stretch...96f&vxp=mtr
for $43 it leaves a decent amount of money for a good indicator
Re: stretch guage [Re: jamesc] #1407095
03/23/13 10:23 PM
03/23/13 10:23 PM
Mt.Vernon ,Ohio
VernMotor Offline
VernMotor  Offline
Mt.Vernon ,Ohio
That's good James. I have some good gauges . thanks
